Tip & How-To about Apple iPod touch
How to connect an iPod to a speaker Yamaha Bar
Yamaha speaker bar is a long, thin speaker system that is typically connected to a television because she can sit on the set. However, many people store their music libraries on iPods, and if you want one of those people you can connect your iPod directly to the Yamaha speaker bar. This is a fairly simple task that can be achieved in just a few moments.
1. Place the iPod in the iPod speaker dock from Yamaha as a bar, or connect your iPod through your door in the background that comes out the opposite. Depending on the model, the speaker dock or a bar directly above the control panel or a cable that runs from the back of the unit.
2. Power bar speaker Yamaha, do the same with your iPod.
3. Choose your music to play through the iPod screen. Press "Play" and you should listen to music through the speaker bar.
Apple iPod touch Logo
don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
front speaker output is not working
Firstly ensure that the 'mute' has not been accidently engaged.
Have you tried connecting other speakers to the same output and cables? If the sound now works, the problem is with the speakers (providing all amplifier settings are correct and wiring is correct). It would be highly unusual to have a problem with both speakers or two sets of cables. Alternatively connect the problem cables and speakers to an alternative source. If they work on an alternative, you are looking at an amp issue.
Aug 29, 2008 | Yamaha RX-V890 Receiver
Mitsubishi 55" Rear Projection - No sound and volume bar continuosly displayed
First unplug the a/v receiver and then check tv to see if the audio output is on or internal speakers. With the a/v rec. you should have chosen the variable audio and not leave on int speakers. If this does not work unplug set for at least an hour and try again. You can get additional info from www.ctechnicians.com
Nov 28, 2007 | Mitsubishi WS-55513 55" Rear Projection...
2,772 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
