Tip & How-To about Apple iPod touch
How do I connect my iPod to a stereo Kenwood
The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod.
1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see.
2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack.
3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected.
4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off
Apple iPod touch Logo
i bought a kenwood car stereo at the flea market and when i got home i found out that it has a lock code,is there any way to reset it without the remote control or shipping it to kenwood? it kdc mp628
you have a problem
one is able to set security code without the remote
without the security code ..not a chance to over ride it
a unit reset wont change the security code
check the user manual link
Kenwood KDC MP628 Manuals
options
back to the flea market see if the seller is there.. for a refund
or contact that flea markets organizers to track down the stall operators details
you can try and contact kenwood car stereo company direct
in your part of the world
this is USAs other countries have their sites
http://locator.kenwood.com/
if you have the gift or sweet talking
they may give you an authorized kenwood repairer to take the stereo to ...and get the code number for you
Oct 14, 2016 | Kenwood KDC-MP628 CD Player
cannot get it to power on How does it work?
Kenwood Excelon DDX9902S DVD receiver at Crutchfield ...
www.crutchfield.com > ... > In-dash Video Receivers Crutchfield Corporation
Rating: 4 - β€Ž21 reviews - β€Ž$674.99 - β€ŽIn stock
Kenwood Excelon DDX9902S Android Auto integrates your phone's app with the ....deliver an ultra-clean signal for adding additional amps for even more power. ...... Only thing I can't get to work with the Apple Car Play is the ITunes radio.
Car Stereos FAQ - Crutchfield
www.crutchfield.com > ... > Car Stereos
Crutchfield CorporationJump to What's the best way to connect the Crutchfield wiring ... - A: Most CDreceivers will play at least ... for example, some receivers work with ... If you can'tfind a new cassette deck ... the remote wire did not power the amp .... KenwoodExcelon KDC-X399 ... 12 tips for getting the best sound quality in your car.
Kenwood KDC-BT362U CD receiver at Crutchfield.com
www.crutchfield.com > ... > All Car Stereos
Rating: 4.5 - β€Ž174 reviews
A smartphone haven With Kenwood's KDC-BT362U CD receiver, you can ... A newcar stereo offers power that's superior to most factory radios, along with .... Gettingthe installation kit and the wiring harness with my stereo purchase was great. .... Cons: Pandora did not work and I tried contacting customer service and their ...
Kenwood - Car-Audio FAQ
Jan 06, 2016 | Kenwood Car Audio & Video
My TV has audio (left & right) & video jacks (red,white &yellow) can I connect my Kenwood KR-V5580 to it for stereo sound If so what do I connect it to video 1 or 2, phone,etc
Audio can usually go either way to a TV. In or Out. Why someone would want to hear external audio through a TV's marginal audio electronics and speaker(s) is beyond me, but sometimes that is what they want.
Take the audio from the receiver via whatever unused Tape or Video function connectors you like to the TV's Audio L & R IN. Anything the receiver processes will be audible through the TV as long as you DON'T select that function for listening on the receiver.
Listening to TV-related audio through the receiver and its (presumably better) speakers makes much more sense, but again, the TV's marginally audio capabilites place a serious limitation on sound quality expectations. In your case, stereo is as good as it could be.
If your TV has Audio Out jacks, just run them to any convenient Line Level input (NOT Phono). If your TV has internal audio controls for volume, set it to Fixed so the TV's volume control doesn't affect the sound going out to the Kenwood.
A better TV-related audio solution would be to connect the BEST audio of whatever source you're watching directly from that source to the receiver. Cable, DVD/BD, SAT always have 2-channel analog RCA connectors as well as (unusable on the Kenwood) digital audio outputs.
VIDEO from the Kenwood to the TV:
You describe your TV having Composite (3 -RCA-style cables). The Kenwood is limited to Composite (Lower-quality, single Video RCA-style cable). Check your TV for a single Video In connection and run THAT from the Kenwood's Monitor Out so you can pass other video through the receiver.
In its day this receiver was pretty high-end but to really enjoy modern multichannel audio from video sources you might consider an upgrade to a true multichannel Audio Video Receiver. For one thing it would support digital audio and probably Component and HDMI video. You could still use the Kenwood's amplifiers to drive speakers or as a secondary system.
Apr 29, 2010 | Kenwood KR-V5580
Cannot get the receiver to connect to a newer
It would be the rare TV that originated anything approaching the sound quality of any other audio source in your home or could process digital multichannel audio anywhere near as well as the Kenwood. What model TV did you say this was? Its internal audio controls could also be part of the problem.
TV-related audio is best derived from as close to its source as possible. Your cable, satellite DVD, BD all have superior digital multichannel audio outputs. Why would you want to filter them through the TV first?
Those sources may also have HDMI which would be great for the TV; they also have standard RCA stereo outputs, each of which could be suitable to run to the TV's RCA inputs if you only want to watch news or weather with lo-fi sound.
Bottom line recommendation: BEST video to the TV; best audio to the Kenwood.
Mar 20, 2010 | Kenwood VR-507 Receiver
2,547 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
