Tip & How-To about Apple iPod touch
How do I connect multiple iPods to One Computer
Suppose you have more than one iPod that you want your computer. Or maybe you have two people with the same computer, otherwise synchronize their iPods. There are a few different ways to go about it. Windows and Mac OS you can run multiple iPods with USB cables and your music library to open. But you can use these methods to various media files to synchronize multiple iPods.
Create separate iTunes libraries
1. Keep the "Options" key while you open iTunes on your computer, if you use a Mac the same way, hold down the "Shift" key while you open iTunes and Windows. This will be a new dialog.
2. Click on "Create Library". Name the new library and save it. iTunes will open this new library you created.
3. Open "Preferences". Do this by selecting "iTunes" and "Preferences" on a Mac, and "Edit" Preferences "in Windows. Click the" tab "Advanced.
4. Check the box next to "Copy files to iTunes Music folder when adding to library." Click "OK". This will ensure duplicate files are not included in your new library.
5. Add the files you want to add in your new library, which are the files you want to go to your second iPod. To do this, drag the files from your hard drive in iTunes. You can also choose "File" and "Add to Library". Add to your library until you see the way you want.
6. Connect your iPod to your computer via USB. Sync your iPod to your iTunes library. Quit iTunes once the synchronization is complete.
7. Repeat step 1 to re-open iTunes. Select "Choose Library". Now your original or the new library you created to switch between the music from your iPod library.
Create separate user accounts
1. On a Mac, select the Apple menu. Choose System Preferences. Select the "View" menu and select "Accounts." Click the "+" to create a new user. Connect your iPod to iTunes and sync with this user.
2. In Windows, click the "Start" button. Go to the Control Panel. In "User Accounts and Family Safety", select "Add or Remove User Accounts." Click on "Create a new account." Connect your iPod to iTunes and sync with this user.
3. Log off your account and to switch between users. This way you can sync your iPod separately for each user. It can be useful if multiple users have different tastes in music. They may have their iTunes libraries and iPods.
Sync iPods with different playlists
1. Open "iTunes". Create multiple playlists to be synchronized with each of their iPods. For example, you can create a playlist of workout you just upload to your iPod nano, in turn, allows your entire library on your iPod touch.
2. Connect your iPod via a USB cable. You can do one at a time or simultaneously on a Mac Windows does not support synchronization of more than one iPod at a time.
3. Click on the first iPod in "Devices". In the "Music", select "Sync Music." Select "Selected playlists, artists and genres."
4. Click Apply. This will start the synchronization process. Repeat this process for the other iPods.
Apple iPod touch Logo
my ipod is screen locked and now as i dont know the password i cant unlock it.since many days ive been tryin so many combinations but still it cant be unlocked. wat am i suppose to do????
Taken from the apple website.
http://support.apple.com/kb/HT1350?viewlocale=en_US
Unlocking iPod
You can unlock iPod in one of two ways:
  • Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
  • Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
  1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
  2. Connect your iPod to the computer that you want to be the primary computer.
  3. Open iTunes and synchronize.
Mar 05, 2011 | Apple iPod nano
IPOD Shuffle deletes songs if I delete them from the music library in Itunes
You have to keep all the songs that you want on your iPod on your computer, otherwise you will get this problem. So if you want song "a" on your iPod it must also be in your iTunes library at all times unless you don't want it on your iPod anymore
Oct 03, 2008 | Apple iPod shuffle Second Gen. Silver (1...
1,681 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
