Tip & How-To about Apple iPod touch
How to make a connection to an iPod and Sony SS2300
The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system.
1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod.
2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod.
3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected.
4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system.
Apple iPod touch Logo
Please define Blue ray technology.
Blu-ray is the next-generation digital video disc. It can record, store and play back high-definition video and digital audio, as well as computer data. The advantage to Blu-ray is the sheer amount of information it can hold:
  • A single-layer Blu-ray disc, which is roughly the same size as a DVD, can hold up to 27 GB of data -- that's more than two hours of high-definition video or about 13 hours of standard video.
  • A double-layer Blu-ray disc can store up to 50 GB, enough to hold about 4.5 hours of high-definition video or more than 20 hours of standard video. And there are even plans in the works to develop a disc with twice that amount of storage.
Oct 16, 2014 | Televison & Video
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to the Kenwood via coax (rca cable). The Kenwood automatically detects the Dolby Digital from the cable box but not for the blu ray. I also tried connecting the blu ray directly to the receiver via optical (fiber optic line) and still all I could get was Pro-Logic.
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Distorted audio on my surround sound
If it does it with just the one disc it is probably the file that you burned. Does the file sound ok on the computer? Sometimes files that are downloaded have bad audio tracks and I have seen cases where the encoding software that you are using messes up the file when it is modifying the file.
Try another DVD or Blu-Ray disc and see if it still distorts. If it does then it may be a setting in the player or in the receiver.
Cheers
Jan 01, 2009 | Sharp BDHP20U Blu-Ray Player
NO SURROUND SOUND WHEN PLAYING BLU-RAY
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Jan 01, 2008 | Sony Playstation 3 (PS3) Console
747 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
