Tip & How-To about Apple iPod touch
How can I connect an iPod to work through a car stereo?
An iPod can store hundreds of songs makes it an ideal source for music on your car. Buy an adapter is the easiest and cheapest way to connect your iPod to your car stereo system. Do you know which adapter fits you best and know how to use the first steps to expand their musical possibilities.
Tape deck
1. Buy an iPod adapter cassette player, if your car has a cassette player. This is one of the easiest and cheapest way to get your iPod to play music from a car radio. A cassette adapter is shaped like a tape with a wire connected to an end.
2. For a cassette adapter or a store of electronic music in good standing. This adapter is relatively easy to find and can usually be purchased for less than $ 20.
3. Slide the cassette tape in the car. Take the end of the cable and connect the headset to your iPod. Select a song to your iPod and press the "Play". Be sure to order the car stereo's cassette player.
FM Transmitter
1. Purchase an FM transmission adapter if your car has a cassette player. This type of adapter connects to both your iPod headphone jack or car cigarette lighter and stream music via FM radio signal.
2. In an FM adapter to send any electronics store. This adapter is a little more expensive than a cassette adapter. Make sure you have an FM transmitter instead, for many FM stations broadcast from a transmitter can only be transmitted to a unit to buy. This gives you more options when you're in certain areas where FM stations are vague or nonexistent.
3. Connect the FM transmitter for the iPod to a lighter (depending on model purchased). Turn on your car's FM radio and find a channel that is unoccupied. Adjust the transmitter to the channel number exactly the same and then to match the iPod. For example, 99.1 FM if you find a free channel in your area, the FM transmitter on 99.1 reading. Connect the iPod and press "Play."
Extra-
1. Purchase an additional cable if your car has an auxiliary input panel. This type of iPod adapter is one of the easiest ways for your iPod to play music in the car.
2. Find a reputable shop and buy an electronic overhead. This type of iPod adapter is usually sold for about $ 10.
3. Connect the cable to the extra auxiliary input on the dashboard of your car and plug it into the iPod headphone jack. Make sure the sound of the car is in standby mode. Select a number and press the "Play" button on the iPod to the music to start.
Apple iPod touch Logo
how do i delete songs of my i pod
The first way is uncheck the songs you want to delete on iTunes and then sync iTunes with ipod again, then the songs you want to delete will lose from iPod.
The second way is use leawo iTransfer to delete songs from iPod, the way is connect iPod to leawo iTransfer, then right click on the music you want to delete from iPod on leawo iTransfer to choose "Delete", then the music will be deleted soon. However, this tool can only work on Windows computer.
Jul 30, 2012 | Apple iPod touch
how to add new mp3 songs
Install iTunes
Before you connect your iPod shuffle to your Mac or PC computer or use it, you must install the latest iTunes software.
2. Connect and Set Up your iPod shuffle Charge your battery by connecting it to an Apple iPod Power Adapter or connect your iPod to a high-power USB port —one that's located directly on your computer—to ensure that your computer charges your iPod battery. (If your computer doesn't seem to recognize your connected iPod , wait about 30 minutes to allow the iPod battery to charge before going further.)
3. Fill your iPod shuffle and iTunes with Music Once you finish the set up, iTunes will open. It will then either:
  • Automatically start filling your iPod with music from your iTunes library (if you set iTunes to automatically update your iPod)
OR
  • Allow you to pick and choose what music, audiobooks, and podcasts to add, if you opted to manually manage music on your iPod.
To manually add content, simply drag any file from your iTunes library or playlist to your iPod icon in the iTunes Source list. If you're using iTunes for the very first time, you'll need to add some music to iTunes first, such as songs from your own CDs or music already on your hard drive.
4. Disconnect your iPod shuffle Once you've got your music, audiobooks, and other files on your iPod, you're ready to enjoy it.
  • If you see an “OK to Disconnect” message on your iPod, simply disconnect it from your computer.
  • If you see a “Do Not Disconnect” message, click the eject icon that appears next to your iPod icon in the iTunes Source list and then disconnect your iPod from your computer when you see the “OK to Disconnect” message.
  • Disconnecting my iPod shuffle
5. Play your iPod shuffle Now you’re ready to enjoy your iPod.
Sep 14, 2010 | Apple iPod shuffle MP3 Player
what hapen when I make update on mi ipod
Back the songs up by connecting your iPod to the computer, opening up the iPod icon in My Computer, and opening the music folder. Create a temporary folder on your desktop to store the music. Drag the music files from the music folder of the iPod to the temporary folder you have just created on the desktop. Now you can update the player, which will erase your songs, but your music will be available to redownload onto the iPod.
-Tha Mp3 Doctor
Jan 07, 2009 | Apple iPod MA446LL/A MP3 Player
music
Get your iPod.
Connect it to your computer.
Start iTunes program.
In the source list, select your iPod.
Now click on iPod options.(On the bottom right corner of iTunes) and select Manually manage songs and playlists option.
Click ok and done!
So here' s how you remove songs form your iPod manually.
  • Connect your iPod to your computer.
  • Go to the source list and click on the icon which looks like an iPod.
  • Choose the songs you want to delete and press delete! How simple is that?!
How to remove songs from your iPod automatically. (When you iPod is set to default settings)
  • To remove songs from your iPod automatically, just delete the songs you want to from your iTunes library.
  • When the default setting is on, songs that are deleted from your iTunes Library will also be deleted from the iPod.
hope this may help;
DON'T FORGET TO RATE;
Aug 22, 2008 | Apple iPod nano
Cannot play 2 song on my ipod
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Hopes it may help you;
Regards,
VOTIT
Aug 04, 2008 | Apple iPod nano 2nd Generation MP3 Player
703 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
