Tip & How-To about Apple iPod touch
How to connect an iPod to a computer connection
The iPod is one of the world's most popular MP3 players because of its ease of use. You can simply drag and drop video and audio files from your computer to the device to your collection on-the-go media to expand. The process of establishing this connection with your computer is easy, and maker of the iPod, Apple only requires that the freedom of the media management program, iTunes downloads to begin adding audio and video on your iPod.
1. Identify your hardware. If you use a computer with a USB 2.0 port, then you have it easier because all you have to do is plug in your hardware. If you are using an older computer (usually with an operating system to Windows 2000), then you have a USB 2.0 port, in which case you should consider using a FireWire or USB 1.1. If you do not have FireWire or USB 1.1, you need a card or adapter.
2. Identify your iPod. Fifth-generation iPods or later can be connected using standard FireWire adapter cable option, but otherwise requires USB 2.0 ports. You can also use standard iPod USB 1.1 ports, but it requires an adapter. The Nano and Shuffle models can only connect via USB ports.
3. Connect the iPod cable that you use on your iPod. The larger end of the cable should fit in the bottom of your iPod, whether it is a standard FireWire cable or dock to the USB 2.0 connection.
4. Connect the other end of the cable to the designated location. For USB users, this will be a USB port on your computer. If you use FireWire, and connect it to four or six-pin FireWire is not.
5. Download and install iTunes if you do not have the software. It is a free program your iPod. If you had installed before establishing the connection, it will open and audio / visual files or on their own. After transferring to your iPod files to load or eject.
Apple iPod touch Logo
my ipod not transfer in ipod |bacu my ipod settings wrong
Now you can transfer iPod files with Bigasoft iPod Transfer between computer and iPod even without iTunes installed! Bigasoft iPod Transfer allows you to copy iPod music, videos, and playlists back to computer. You can even import favorite computer files or folder to iPod with simply drag and drop.
In addition to managing between your iPod and computer files, the powerful iPod file transfer can not only copy iPod to iPod, but simultaneously transfer files among multiple iPods.
The iPod manager supports various types of iPod, including iPod classic, iPod nano, iPod shuffle, iPod touch, iPhone, and iPad.
Free download Bigasoft iPod Transfer and easily manage your iPod / iPhone / iPad in your own way!
May 06, 2010 | Apple iPod MA446LL/A MP3 Player
I am computer illiterate so this may be a long one. I have a Sansa Fuze MP3 Player 8gb Silver. Also I already have a Itunes account and library can I drop library into the Mp3 player or is their a website "MP3 Setup for Dummies"
It is my understanding that downloaded iTunes music only works with iPod products. However, you can create your iTunes music into MP3 format in your iTunes library. Your MP3 player should come with the software needed or tell you which application to use (ex. Windows Media Player). After you've created an MP3 version you can import/export into the proper media application then sync to your MP3 player.
Info I found on the web about your MP3 player:
Compatible Formats
The player supports MPEG4 video files and audio files saved in MP3, secure and unsecured WMA, WAV, Audible, and Overdrive file formats.
Simply connect the player to a PC, and start dragging files from your Windows Media Player 10 or 11 applications.
Dec 27, 2008 | Audio Players & Recorders
649 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
