Tip & How-To about Apple iPod touch
How to Speed Up Internet on my Touch Pro 2?
The HTC Touch Pro smartphone 2 is avaialble for T-Mobile and Sprint subscribers, and uses the data network cell phone to connect to the Internet. While the Internet connection is based on a strong 3G connection for fast browsing, you can also activate the Wi-Fi device to connect to a wireless network. Available Wi-Fi networks within range of the Touch Pro will be displayed on the device are on the list of networks. Once connected, your Internet speed is capable of data based on the strength of the wireless signal to send.
1. Slide your finger on the "Home" screen to the tab "Settings" appears. Play the "Communications" button.
2. Touch "Wi-Fi" on the phone screen, then hit the wireless network is displayed in the "Discovered Networks" list.
3. Type the network security key using the onscreen keyboard, and press "Done" for the network to connect. A wireless signal appears at the top of your phone screen when connected to Wi-Fi network successfully
4. Touch "Back" to return to the "Communications" menu.
5. Play the "ON / OFF" in "communication" from the menu for Wi-Fi off. It is important to turn off the Wi-Fi functionality when not connected to a wireless network, because this mode the battery is not on.
Apple iPod touch Logo
i can not unlock my htc touch pro 2
Do not worry using codes you can unlock your HTC mobile because its easy and safe for your mobile............
Get the unlock code for your HTC touch pro 2 model mobile here Simpleunlocking.com , it gives the easy instructions to get your mobile as unlocked at a safe way.....
Dec 14, 2011 | HTC Touch Pro 2 / Tilt 2/ HTC XV6875/ S510...
Hi. I have an htc touch pro2 sprint it has no data connectionand phone calls work on and off. I need the correct data settings for unlocked Sprint htc touch pro2 unlocked for Boost Mobile! Can you please help?
Why don't you ask Boost, then? Those settings are not device-dependent. As soon as you have them, input them via settings->connections. All you should need it
a) the APN of the connection (a name)
b) whether they require the use of a proxy
b1) if yes, the IP address and the port of it
c) whether they require authentication (that's usually not the case)
c1) if yes, your username and password
That should be all.
Jul 02, 2010 | HTC Touch Pro2 Smartphone
I have a Touch Pro 2 from Sprint. I can't receive text messages or calls.
Reset your phone then try again, if still not working unlock your phone network using htc touch pro2 unlock code. This code can you get from your network provider or you can buy from online htc unlock code retailer.
Dec 26, 2009 | HTC Touch Pro2 Smartphone
921 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
