Tip & How-To about Apple iPod touch
How to convert a USB Battery Charge Cable to AC
Many of the new battery-operated devices such as phones and MP3 players come with USB cables to charge the battery while the computer. However, wall chargers for these items are missing, damaged or undelivered. If so, you can use a USB wall charger, USB cables, adapters and because all have the same size at the end with these boots are endless.
Generic Battery
1. Buy a USB wall charger. These are available online through www.amazon.com and www.bixnet.com or a limited number of electronics stores like Radio Shack or Best Buy.
2. Connect the USB end of cable to the USB wall charger.
3. Connect the charger to the USB cable. Then connect it to the wall. The machine starts working the green light.
iPod Battery
1. Connect the USB cable to the iPod. Be sure to press the two ends before inserting it into the iPod. If you do not, you can damage the pins, once that happens, you will not be able to charge your iPod.
2. Mount the USB wall charger sliding the top in half, for the manual.
3. Connect the USB cable for both USB wall charger. Plug the wall charger. The costs start when the lights come back on the iPod screen and you will see the battery icon fill. You can find this anywhere iPod charger are supplied.
Apple iPod touch Logo
How dont know how to charge my mp3 player
Some things to check for when your player does not act like its taking a charge. USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems). USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device. Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery. Latest firmware Depending on what player you have, make sure it's up to date with the latest firmware. AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
Dec 25, 2010 | Philips GoGear Flash MP3 Player
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
HI, MY NAME IS ANGELA. I PURCHSED A SANSA MODEL
The Sansa charges via the USB cable. Fully charged, it should be good for 12-15 hours of playing. Be aware that not all computer USB ports put out enough current to charge external devices. If your computer doesn't charge the Sansa, try a different computer. You can also charge the Sansa using other USB charges, such as you'll see for charging cell phones from a wall outlet or a car cigarette lighter.
Jul 23, 2010 | SanDisk Sansa e250 MP3 Player
Zune 30GB won't charge in car.
Some auto usb cables aren't compatable with Zune device.
Mar 07, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Please Help
Hello Pookie34,
In general, most MP3 players are charged by connecting them to the USB port on your computer using the supplied programming cable. Make sure you are connecting the cable to a USB port on the computer itself and not a USB hub as most USB hubs do not have enough output power to charge your device.
Your MP3 player can also probably be charged by connecting it to an appropriate AC wall charger or automobile power cable. However, for most manufacturers these are optional accessories not normally included with the player.
Best Regards.
Ken
"Go Ahead. Use Us."
Jul 22, 2008 | Memorex MMP8565 MP3 Player
760 people viewed this tip
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
