Tip & How-To about Apple iPod touch
The battery of my iPod is not charging
When you buy an iPod, the device comes with cables that connect the charging device to the computer. When the iPod battery is low, you can recharge by plugging into your desktop or laptop. But sometimes, when you connect your iPod to your computer, the battery charger. According to Apple's site, some problems may prevent your iPod from charging properly.
1. Connect your iPod USB charging cable only one USB port on the computer itself. External port devices, such as a USB hub, do not provide enough power to recharge your iPod.
2. Connect the iPod firewire charging only one firewire port on your computer. Like USB, Firewire ports are not enough of a load to the battery of your iPod.
3. Disconnect the computer from sleep when the computer set to sleep after a certain time. An iPod can only load on a computer that is connected and not in sleep mode. To enable sleep mode on most computers, you can move the mouse or press the power button once. Hold the power button, which usually turns off the computer.
4. Turn the iPod off and on when the unit is frozen. A frozen iPod is not charging. If the unit is still frozen when you turn it on again, restart the iPod by pressing the "Hold" switch to "On" and then back to "Off" and press and hold a "Menu" and "Select" buttons simultaneously or " Start "and" Menu "button. Hold the buttons until the Apple logo appears on the screen.
5. Set the system up-to-iPod charger so that when using a Windows 2000 computer. In preparation for the system to load the iPod device to the unit with the charging cable, launch iTunes and "iPod" in the left pane to "Settings" tab to go, check the box next to "Enable Disk use", and click the "Apply" button. Once the configuration is in place, the iPod will charge as normal.
Apple iPod touch Logo
i have a 30gb ipod classic it would not turn on and it keep reading battery very low please wait ...so to replaced the battery and it still saying the same thing my friend said that i need a new logic boad is he right?
> is he right?
Maybe. If the cable that connects to the iPod that you use to recharge the battery is broken, then _NO_ battery (old or new) can get recharged. Borrow a cable from a friend, or connect your iPod to your friend's cable, to see if changing the cable allows the battery to charge.
If that does not help, then your friend could be correct.
Note that some "big-box" stores, such a BEST BUY, will take your iPod as a "trade-in" on a new iPod. Put the old battery back in before you do the trade-in, and sell the new battery on eBay or CraigsList.
Dec 22, 2010 | Computers & Internet
how do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
iPod not charging
your cable might be worn out
Jul 31, 2008 | Apple iPod nano
872 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
