Tip & How-To about Apple iPod touch
The iPod USB Charger
The USB cable that came with all iPod has two purposes: to your device to your computer so you can update and add music, and iPod to charge. All iPods have a lithium ion battery stops charging when the battery is full, the total life of your battery is not affected if you leave the iPod is connected to a power source. It usually takes four hours to recharge most iPods.
1. Connect the USB connector into an available high-power USB 2.0 port on your computer. Low-power USB ports, such as those in external keyboards and hubs do not work.
2. Connect the 30-pin connector at the other end of the USB cable 30-pin connector on your iPod. If you charge an iPod shuffle, there is no dock connector port. Instead, use the connector on the other end of USB cable that fits in the headset. Set the iPod down and let it recharge.
3. Unplug the USB cable when the iPod battery indicator is full. If you charge an iPod shuffle, the green light will appear.
Apple iPod touch Logo
how do I record new music on my ipod? I found a first generation iPod in a desk I purchased. I have purchased a cord to play the music already recorded through my car, but have no idea how to charge it or get music I like on it. Thanks.
to charge the ipod you have to plug the usb cable if you have one, to the computer or you can purchase a wall charger. for adding, deleting,or edit any content in the ipod you need to do it thru itunes plugging your ipod to the computer with the usb cable. in itunes you will see the ipod appear under devices.once you have add the songs you want to the itunes library,(if you don't want to keep the songs you already have) clip on the ipod under devices and just press sync, if you do want to keep the songs then when you click on ipod you will see where you can check and uncheck options,is right under version you will only check "manually manage musics and videos", now click on the arrow nex to the ipod under devices you will see there all the folders in your ipod. dobble click on music to open the music folder in your ipod in another window now drag and drop the songs from the itunes library to the music folder in your ipod. and your done. here are a few pictures to help you better.
http://i282.photobucket.com/albums/kk249/latinapr2003/untitledtytrgf.jpg
http://i282.photobucket.com/albums/kk249/latinapr2003/untitled.jpg
http://i282.photobucket.com/albums/kk249/latinapr2003/untitledty.jpg
hope this helps you take care
Feb 23, 2011 | Apple iPod nano
809 people viewed this tip
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
