Tip & How-To about Apple iPod touch
How can I open my iPod on my Mac Desktop?
When you connect your iPod to your Mac desktop or laptop computer, the iPod name and the icon on the desktop. Most people have no opportunity to open the iPod from the desktop to iTunes music on a regular basis, generally have short, any securities, making them difficult to recognize. However, if you use your iPod in disk mode - basically a portable hard drive - to open your Mac desktop is the fastest way to open the files.
1. Connect the cable from the iPod charger to the bottom of the iPod and the other end into a USB port on your Mac should be noted that the iPod shuffle is upside down in the dock.
2. Wait until the iPod appears on the desktop. If not, pull and plug the charger cable, sometimes it takes a couple of tries.
3. Double-click the iPod icon on the desktop when it appears. IPod open up and show your files.
Apple iPod touch Logo
ipod locked need four didget unlock code
  • Step 2 Plug the other end of the iPod USB cable into a free USB port on a Mac2.gif or PC computer.
  • Step 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
  • Step 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
  • Step 5 Click on the "Sync" button to establish a connection between your iPod and the computer.
  • Step 6 Click on the eject symbol next to your iPod's name after the syncing process has finished.
  • Step 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again.
  • Sep 28, 2009 | Apple iPod nano
    how do i unlock my apple ipod
    1. Plug the iPod USB cable into the bottom of the iPod Nano.
    2. Step 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
    3. Step 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC.
    4. Step 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window.
    5. Step 5 Click on the "Sync" button to establish a connection between your iPod and the computer.
    6. Step 6 Click on the eject symbol next to your iPod's name after the syncing process has finished.
    7. Step 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again
    Sep 22, 2009 | Audio Players & Recorders
    my ipod is locked my computer crashed and i need to find a way to unlock it
  • Step 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer.
  • Sep 22, 2009 | Apple iPod touch
    how do you add your name to you ipod in settings?
    With your iPod connected to either a Mac or PC using iTunes:
    1. In iTunes goto the iPods main page
    2. Click once on the iPod name in the Devices section on the right hand side to select it
    3. Click once more to be able to edit it.
    4. Eject the device by clicking the eject symbol to the right of it's name.
    5. Done!
    Without iTunes on a Mac or PC
    1. On a PC open My Computer
    2. Locate the mounted device and right-click (Ctrl-Click on a Mac) it's icon.
    3. Choose 'Rename [iPod]' from the list.
    4. Rename it
    5. Done
    All the best
    Sean
    PiDigital
    Dec 10, 2008 | Apple iPod nano
    Why isn't the charging icon always animated (flashing)?
    For Mac users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes.The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. If the charging icon is flashing and your computer doesn't recognize it,Can't see your iPod in iTunes or or the Finder? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB or FireWire port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or in the Finder when you connect it to your Mac. The most likely causes are listed below in logical order (you'll find information for both USB and FireWire iPod connections). Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. Battery depleted? If you have an iPod nano, click here to find out what you'll see if the battery is depleted. If this is what you are seeing, wait 10 minutes while iPod nano is charging. You're using USB instead of FireWire If you use USB instead of FireWire to connect, it won't appear in iTunes unless you update to Mac OS X 10.3.4 or later. If you can't update your software, then use FireWire instead. Note: iPod shuffle and iPod nano are compatible with USB only. With any model of iPod (except for iPod shuffle), if you connect it to a low-powered USB port (such as one on your keyboard or bus-powered USB hub), the following alert may appear: If you click OK, your iPod won't appear. Make sure that you connect your iPod directly to one of the computer's USB ports or to a powered (as in connected to an electrical outlet) USB hub. Your Mac is sleeping Your Mac must be awake to recognize iPod. Be sure that you wake the computer before connecting your iPod. Your Mac doesn't meet iPod system requirements Make sure that your Mac meets the iPod system requirements. Third-party FireWire and USB cards and PC cards may not work and are not supported by Apple. You're missing some system sof
    Sep 28, 2005 | Apple iPod nano
    762 people viewed this tip
    Top Apple Audio Players & Recorders Experts
    Nagendra Baliga
    Parshiv Luthra
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
