Tip & How-To about Apple iPod touch
How do I Clean iPod Ear buds
IPod ear buds can get grungy from regular use and should be cleaned and disinfected frequently. If your iPod headphones with others, there is potential for the transmission of germs and infections. Be sure to immediately disinfect your earplugs if someone uses them.
Soap and water clean
1. Disconnect the headphones from the iPod.
2. Mix a mild soap with warm water. Dampen lint-free cotton with soap and water mixture. Wipe the earphones with a damp cloth. Do not get water into the holes.
3. Enter the cloth under warm running water. Rinse to remove all soap. Twist the cloth to dry. Wipe the earphones to eliminate soap residue.
4. Rub a clean, dry cloth over the headphones to dry them.
Disinfection with hydrogen peroxide
1. Buy a solution of hydrogen peroxide 3% or disinfectant wipes. This product is available in pharmacies and supermarkets.
2. Dampen a clean lint-free cloth to clean the peroxide and the headphones.
3. Wipes clean with a pre-designed for cleaning hearing aids if you do not feel comfortable using a solution of hydrogen peroxide. These scarves are not guaranteed damage plastic, silicone or rubber.
4. Carefully wipe the headphones with a clean, lint-free.
Apple iPod touch Logo
The speaker on my ipod plays even when my headphones are plugged in. How do i turn off the internal speaker?
un plug ear buds
reset ipod by holding menu and center at the same time for 30 seconds till you see the apple logo - - then reconnect ear bus make sure they make a clicking sound and there is no gap
play a song to test
Apr 05, 2010 | Apple iPod nano
i have purchased 2 sets of just basic headphones for my ipod within a month of each other and both lose sound completely in one earpiece. Whats the problem; my ipod is less than 6mths old thankyou
It is the ear buds, not the player. These ear buds marked for iPods but cost $10.oo or so do this, I went thru 3 sets before I gave up and went to a $29.oo set that I have had now for 5 months.
Feb 03, 2010 | Apple iPod shuffle MP3 Player
My ipod video 30 GB is only playing sound out one ear.
one of the connections in your ipod is broken/bent. there is no good way to fix this youself. contact apple or go to your nearest apple store to have them fix it
Aug 06, 2009 | Apple iPod MA446LL/A MP3 Player
Losing sound in my Shure ear buds, they are one year old.
the wire breaks after a while in ear buds ,and head phones due to the constant flexing,and moving.they probably need to be remade.by cutting out the bad part of the wire(usually close to the fitting)You can usually wiggle the wire and find where the breaks are that way.it can be a real pain re soldering ear buds.also check the plug end by wiggling the wire there.
Mar 16, 2009 | Shure SCL3 Headphones
Only the left ear bud has sound
Hey NoRightSound,
If your earbud headphones function normally with other devices, there are a number of reasons why this problem may be occurring, including faulty connections within the iPod itself or a potentially defective headphone jack. While both of these issues can typically be resolved fairly easily, I would first suggest contacting your local Apple-authorized service center for a complete diagnostic to pinpoint the exact cause of the problem.
Remember that if your iPod is still under the original manufacturer's warranty, you can always call Apple directly for technical support over the phone in addition to working with a technician in your area.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 22, 2008 | Apple iPod classic MP3 Player
710 people viewed this tip
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
