Tip & How-To about Computers & Internet
What Is A Driver, Why Isn't Mine Working and Where Do I Get One
What Is A Driver and Why Won't Mine Work?
A driver is software, a program, that allows your computer to
communicate with hardware or devices. Without drivers, the
hardware you connect to your computer­for example, a video card or
an audio card, printer etc will not work properly. Think of it
like driving a car. It doesn't help to just turn it on if it's
only going to sit there in the parking lot. It needs to know
where to go and how to get there and what to do.
It Looks Like I Have One, But It's Not Working--- Why?
There are several reasons why you can have a driver installed but
the device doesn't work. If it was working but now it's not the
file - driver - may have gotten corrupted. The resolution is to
reinstall the driver. If you have installed a new version of
Windows it may not work with the old driver. You will need to
download a new driver for the specific version of windows you're
using.
Where Can I Get One?
The best why to get the proper driver for your device is to go to
the manufacturer's website and download it for the particular
operating system (ie windows vista) you are using. If you have a
laptop start by going to Google or another search engine and
SEARCH for the brand name of your laptop, ie "toshiba". In the
results look for "support" or "downloads". If you dont' see
that listed in the search results then just to to the main site,
ie toshiba.com and then look for a tab or link (usually at the
top of the page) that says SUPPORT or DRIVERS & DOWNLOADS.
Once you get on the proper page of the site you will need to match
the exact model of laptop you have and the operating system you
are using. It will then take you to another page that has a list
of drivers and other downloads available for your laptop. Look
for the one you need and download it.
If you are needing a driver for a desktop or an add-on device for
your laptop, such as a printer, then SEARCH on Google or Bing
for the manufacturer's (name) site, ie "epson". Again you're
looking for SUPPORT or DRIVERS and Downloads. Click on that link
and then put in the model number and operating system to get the
correct driver.
On occasion your machine may not like a new driver but will work
if it is "rolled back" to an older version or you may need to
download an older version. If you are downloading an older
version you will still want to make sure it is one for the
operating system you are using now.
If everything has been working correctly you may wish to turn off
the auto-download updated drivers in your WINDOWS UPDATE so that
it doesn't automatically replace the driver with a new one.
By the way, it is NOT necessary to update some things immediately
when they come out! That includes not only drivers but also such
things as Internet Explorer. I prefer not to be a "beta-tester"
for some things without my knowledge, particularly when what I've
been using works fine. Often there are still kinks being worked
out in the new versions but if you wait a short while they will
start being reported and hopefully the bugs will be fixed, then
you can download it. It's not a bad practice to search google
for " (updated product's name) and problems. For example you'd
put this in a google search __ "interent explorer 9" problems
____ which will give you a return of sites that talk about
problems other's have had with the product.
NOTE: there are always some people/machines that will have a
problem with something that most others don't, so don't
necessarily assume that one bad report means the software is bad.
However if you see repeated reports of the same problem again
and again you can pretty much guess that it's the software that is
causing the problem! If that is the case I would avoid updating
it until you've searched again at a later date and find either no
current mention (look at the dates) of repeated problem or reports
of a fix.
Computers & Internet Logo
cd drive code 39
What the Code 39 Error Is
CD-ROM/DVD Drive Cannot Start. (Code 39)
Code 39 is an error specific to the device manager. It is directly associated to drivers and errors that have occurred within them. Drivers are the small pieces of software that your hardware devices use to function. Each hardware device has it's own unique driver, developed by the hardware manufacturer, that contains the instructions allowing the hardware device to cooperate with other hardware devices and communicate with the operating system. Drivers are essential to the normal operation of any computer as they bridge the gap between hardware software.
Code 39 errors are amongst a wide array of device manager errors that all point to the same problem: the driver. It is not uncommon for drivers to become corrupted and produce errors during normal operation. Drivers are accessed constantly for every operation that a hardware device performs. Because of this, there are thousands of opportunities for errors during a single session of Windows. Because of this high rate of failure opportunity, many users have experienced Code 39 errors as well as many other device manager errors.
manually fixing Code 39 errors. Updating to the most current driver will replace the corrupted file with a new, better driver. Updating the driver will not only correct Code 39 errors but it will also introduce greater speed, performance, stability and compatibility. Driver updates are changes that the developer made to the original driver in the interest of all-round improvement. Driver updates often correct many other errors that are related to device incompatibitlity.To learn how to fix Code 39 errors manually, read this guide. The guide will provide steps for manually finding, downloading and installing the most current driver avaiable for your hardware devices. However, it is generally MUCH easier, safer and more reliable to use an automated tool. We've discussed using an automated tool to fix Code 39 errors below.
DriverUpdate.DriverUpdate is an easy-to-use tool that scans your unique hardware configuration for any device driver problems. Drivers that are out of date, missing, misconfigured or corrupt can easily be re-installed automatically by the program. The benefits of this program are endless. Most users not only have error messages fixed, but also will see a performance improvement since all of their system drivers can be updated! ( click here to download DriverUpdate ) RECOMMENDED
Feb 23, 2012 | Dell Dimension E310 PC Desktop
driver
In computing, a device driver is a computer program allowing higher-level computer programs to interact with a hardware device.
A driver typically communicates with the device through the computer bus or communications subsystem to which the hardware connects. When a calling program invokes a routine in the driver, the driver issues commands to the device. Once the device sends data back to the driver, the driver may invoke routines in the original calling program. Drivers are hardware-dependent and operating-system-specific. They usually provide the interrupt handling required for any necessary asynchronous time-dependent hardware interface.
Jun 26, 2011 | Computers & Internet
I am trying to get my keychain photo to work but i have win7 and my laptop won't read my device. is there another way to get it to work.
If you plug in your device and the computer does not recognize it. You will need to make sure you have installed the latest device drivers. Device drivers allow the operating system to properly communicate with the hardware.
Since you have not provided a brand name for your key chain photo, I can't provide the driver website to you. You can do a simple Google search by the brand name of the key chain and it should take you to the proper website where you can download the software.
Let me know if you have any questions, G33k
Jun 08, 2011 | Microsoft Windows 7 Home Premium 64BIT...
what is audio drive
In computing, a device driver or software driver is a computer program allowing higher-level computer programs to interact with a hardware device.
Dec 17, 2010 | Computers & Internet
what is the drivers
Drivers are software programs written by a device manufacturer for components (such as a sound or video card) which, when executed, enable the device to communicate with your operating system. Most components come with a driver CD that enable you to install the drivers on your hand drive per the manufacturer's instructions.
If you find this information to be helpful to you, please rate my response to you on the FixYa website.
Nov 28, 2010 | Computers & Internet
290 people viewed this tip
David Payne
David Payne
