Tip & How-To about Computers & Internet
LCD monitor any brand repairing tips.
LCD monitor symptoms
1. Have power, no screen light display ( CPU 100% working good ).
2. Dim screen light and black screen display.
Solution
a.Open back cover of LCD and then replace the board of fluorescent lamb that's parts defective need to replacement. if that board of fluorescent of your LCD or laptop. no parts available or no replacement parts for that.(other know LCD monitor disposable can't repair because it's very hard to find parts or replacement parts device)
Please see sample picture.
b. Replacement parts.
Cold cathode fluorescent lamp device is use for motorcycle light accessories and desktop PC accessories. it's very easy to find anywhere motorcycle accessories store, hardware store etc. also very low price.
Please see picture below.
This parts, I already use 5 years ago for replacement of LCD fluorescent lamp board(PCB). up to now 100% working good.
I hope this information will be helpful.
Jimmy C. Verdadero
Fixya team
Computers & Internet Logo
How do I fix akai TV model #lct2785ta? TV screen remains blank and black, after I power it on.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 15, 2015 | Akai Televison & Video
HPw19 monitor
If you are using a laptop, you might have pressed the button to switch from LCD to external display. The key combination depends on your laptop model, but it is usually Fn+F4 or some other function key. Look for a function key that also has an icon looking something like an external monitor. 48d40f3.jpg Try pressing function and that key a couple times to see what happens.
Jul 13, 2008 | HP w19 19" LCD Monitor
the tv suddenly goes black and the power light blinks red
- Flickering screen
- Dim screen
- Slow start
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 12, 2015 | LG 37-inch Led-lcd Tv - 1080p 60hz Hdtv...
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
screen keeps displaying "adjusting...."
- Flickering screen
- Dim screen
- Slow start
Apr 08, 2014 | Hannspree HANNS.G HU196D - LCD display -...
376 people viewed this tip
David Payne
David Payne
