Tip & How-To about Computers & Internet
Windows 7 hidden Wallpapers and Themes
1. In the search box in the Start menu, type C:\WindowsGlobalization\MCT and press Enter. (Note: If Windows 7 is installed in a drive other than C:, use that letter instead.)
2. Windows Explorer will launch and show you a list of subfolders under C:\WindowsGlobalization\MCT: MCT-AU, MCT-CA, MCT-GB, MCT-US, and MCT-ZA. Each subfolder has wallpapers for a specific country: AU for Australia, CA for Canada, etc..
For any of the countries whose wallpaper and themes you want to use, go into its Theme folder, for example, C:\WindowsGlobalization\MCT\MCT-ZATheme. Double-click the theme you see there.
Computers & Internet Logo
1304 error when trying to install microsoft office student 2007
To resolve this behavior, use the following methods.
Method
: Re-Register the Windows Installer
To re-register the Windows Installer, verify the location of the Msiexec.exe file on your hard disk and in the Windows Registry, and then re-register the Windows Installer. To do so:
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
Verify the location of the Msiexec.exe file on your hard disk. To do so:
Click Start, and then click Search.
Click All files and folders.
In the File name box, type msiexec.exe, and then click Search.
In the search results, make a note of the location of the Msiexec.exe file.
The location of the Msiexec.exe file should be similar to the following example, where Drive is the drive where Windows is installed, and %Windir% is the folder where Windows is installed:
Drive:\%Windir%\System32
An example of this is C:\Windows\System32.
Note In Microsoft Windows 98-based computers, the Msiexec.exe file is located in the Drive:\%Windir%\System folder.
On the File menu, click Close.
Verify the location of the Msiexec.exe file in the Windows Registry. To do so:
Click Start, and then click Run.
In the Open box, type regedit, and then click OK.
Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\MSIServer
In the right pane, double-click ImagePath.
In the Edit String dialog box, make sure that the string in the Value data box contains the correct path of the Msiexec.exe file on your hard disk that you determined earlier in step 1.
For example, if the Msiexec.exe file is located in the Drive:\Windows\System32 folder on your hard disk, the correct path of the Msiexec.exe file in the Value data box is the following path, where Drive is the drive where Windows is installed:
Drive:\Windows\System32\Msiexec.exe /V
If the Value data box does not contain the correct path, make the appropriate changes to correct the path, and then click OK.
Quit Registry Editor.
Start your computer in safe mode, and then register the Msiexec.exe file. To do so:
Shut down, and then restart your computer.
Press F8 after you receive the following message:
Please select the operating system to start
On the Windows Advanced Option menu, use the arrow keys to select Safe Mode, and then press ENTER.
If you use a dual-boot or multiple-boot computer, select the appropriate operating system from the list that is displayed, and then press ENTER.
Log on to the computer.
In the Open box, type the following line, and then click OK:
msiexec /regserver
Shut down, and then restart your computer in standard mode.
If the issue persists and you still receive the error message that is described earlier in the "Symptoms" section, follow the steps in Method 2.
Method 2: Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer files, and then reinstall the Windows Installer. To do so:
In the Open box, type cmd, and then click OK.
At the command prompt, type the following line, and then press ENTER, where Drive is the drive where Windows is installed and where %Windir% is the folder where Windows is installed:
attrib -r -s -h drive:\%Windir%\system32\dllcache
For example, type
attrib -r -s -h c:\windows\\system32\dllcache
At the command prompt, type exit, and then press ENTER.
Restart your computer.
Update the Windows Installer files on your hard disk to the latest version. __________________
Feb 22, 2010 | Microsoft Office Professional 2007 Full...
Use hidden international wallpapers and themes in windoes 7 When you first install Windows 7, it asks for your language, time and currency. Based on your responses, it installs a set of wallpapers and themes. If you choose English (United States) for your time and currency format, for example, the available desktop backgrounds and themes will include a United States section with scenery from locations such as Maine, the Southwest and so on. Hidden, though, are background scenery and themes from other English-speaking countries -- Australia, Canada, Great Britain and South Africa. Normally, you can't access those backgrounds or themes, but there is a simple way you can install and use them: 1. In the search box in the Start menu, type C:\Windows\Globalization\MCT and press Enter. (Note: If Windows 7 is installed in a drive other than C:, use that letter instead.) 2. Windows Explorer will launch and show you a list of subfolders under C:\Windows\Globalization\MCT: MCT-AU, MCT-CA, MCT-GB, MCT-US, and MCT-ZA. Each subfolder has wallpapers for a specific country: AU for Australia, CA for Canada, GB for Great Britain, US for the United States, and ZA for South Africa. For any of the countries whose wallpaper and themes you want to use, go into its Theme folder, for example, C:\Windows\Globalization\MCT\MCT-ZA\Theme. Double-click the theme you see there (for example ZA). 3. That will install a shortcut to the theme and wallpapers in the Personalization section of Control Panel. You can now use them as you would any other theme or background, by right-clicking the desktop, choosing Personalize, and choosing a background or theme. They will be listed in their own section.
Jan 12, 2010 | Computers & Internet
is their a program i can download to change my themes for windows 7 starter at first i couldnt change my wallpaper but then i found a program called OC and its possible so i wana know if someone created a program for the theme
Microsoft windows 7 has default 5 theme but Windows 7 beta 1 build 7000 onwards has several hidden & locked themes provided for regional countries such as Australia, Canada, Great Britain, United States and South Africa.Since these hidden themes are installed along with your Windows 7 installation you can unlock/unhide these hidden Windows 7 Themes for regional contries. Below are three deferent methods to get Windows 7 hidden themes.
Screenshot of Default Windows 7 Themeswindows-7-default-themes.jpg Method 1: Steps to Unlock & Unhide Windows 7 hidden locked Themes1. Unhide the Windows 7 System and Protected Operating System files from Windows explorer -> Organize -> Folder and Search Options -> view tab
2. Navigate to C:WindowsGlobalizationMCT.
3. Open a MCT-(AU, CA, GB, US, or ZA) folder for the regional theme that you want.
NOTE: AU, CA and ZA regions all have the same themes though.
4. Open the Theme folder in the selected region folder.
5. Select the .theme file to use it.
NOTE: Once you select a .theme file, Windows 7 will save it so that you will be able to change or select this theme again from within the normal Personalization window location.
6. Hide the Windows 7 System and Protected Operating System files.
7. Enjoy your new regional themes!!
Method 2: Using windows 7 Search (Simplest Method)1. Go to Windowswinsxs Directory
2. Search for *.theme.
winsxs-themes.jpg3. Double click themes with name in the format of XX to apply and save the theme.
Method 3: Registry Entry1. Open notepad and copy past the following lines
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionThemesInstalledThemesMCT]
“%windir%\Globalization\MCT\MCT-AU\Theme\AU.theme”=””
“%windir%\Globalization\MCT\MCT-CA\Theme\CA.theme”=””
“%windir%\Globalization\MCT\MCT-GB\Theme\GB.theme”=””
“%windir%\Globalization\MCT\MCT-US\Theme\US.theme”=””
“%windir%\Globalization\MCT\MCT-ZA\Theme\ZA.theme”=””
[HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerWallpapersKnownFoldersWindows WallpapersMergeFolders]
“%windir%\Globalization\MCT\MCT-AU\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-CA\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-GB\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-US\Wallpaper”=””
“%windir%\Globalization\MCT\MCT-ZA\Wallpaper”=””
2. Save file as allregional.reg on desktop.
3. Double click on allregional.reg to add above registry entry.
4. Now you can access all Windows 7 Hidden & Locked Themes via right clicking on desktop and personalize settings.
We have created allregional.reg file for you, Download allregional.reg and run it on your machine and access hidden Windows 7 Themes instantly.
Screenshot of Unlocked – Unhide Windows 7 Hidden Themesunlock-unhide-windows-7-hidden-locked-regional-themes.png
Feb 09, 2010 | HP Computers & Internet
354 people viewed this tip
David Payne
David Payne
