Tip & How-To about VeriFone (M19755014US1) Magnetic Card Reader
Verifone error messages
Troubleshooting any Verifone product by any third party company including Fixya.com doesn't provide any support for any error messages. It is a credit card machine and I'm sure for security reasons it was purposly done that way.
You can contact Verifone at:
1-800-834-9133
Mon-Fri 8 a.m. to 7 p.m. EST
Manuals are available at this link
VeriFone (M19755014US1) Magnetic Card Reader Logo
TCP error 1001
This indicates an ip connection error.
Unplug the terminal. Wait 5 seconds. Plug back in.
After it reboots you will see two or more menu options. Select CommServer (instead of Credit/Debit) by pressing the function key beside it.
Select Troubleshoot to allow it run through the diagnostics. Push the purple button below "Print" to print the results.
Now select Repair by pushing the function key next to it. After the repair routine has run, press * on the keypad to return to the main menu.
Select Credit/Debit and then try swiping a card and performing a transaction. This hopefully will solve the problem for you. If not, call your merchant services provider's tech support and share the error message and tell them you printed the troubleshooting diagnostics report and they should be able to assist further.
Nov 12, 2012 | VeriFone Vx 570 Dual Comm Credit Card...
The machine will not process credit cards.
contact your processing company
On your monthly statement, it has tech support phone#
http://www.gorillapaper.com/verifone-terminal.html
Oct 16, 2009 | VeriFone (M19755014US1) Magnetic Card...
what is the differance betweeen intel orignal or intel chip set
In an original motherboard, the entire product is manufactured by Intel, i.e. the circuit board and the ICs (integrated circuits) which are on it. Whereas, when we talk of a `chip set' it means some other company, for instance Mercury or D-Link, has designed and made the circuit board but has used the chipset provided by Intel.
When we refer to a `chipset" it is a set of ICs that primarily controls the processor, memory and other main functionalities. However, the third-party company that has designed the circuit board can use other company chips for audio and other communication peripherals. The major point to note here is the design of the mainboard. A good design should provide a good air flow and a perfect selection of peripheral and communication chips to have optimal performance.
Buying a chipset board is always a compromise. However, third-party companies, like the ones mentioned above, do make some good boards that are cost-effective and reliable too
Buying a chipset board is always a compromise. However, third-party companies, like the ones mentioned above, do make some good boards that are cost-effective and reliable too.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 06, 2009 | Intel Motherboard
4,052 people viewed this tip
Top VeriFone Televison & Video Experts
AliennoisE
Bosse Photos
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
