Tip & How-To about Office Equipment & Supplies
Printer IP Address Lookup
Need assistance in looking up for your printer's IP Address?
Often times we see a networked printer suddenly stop working and you need to find a static (private) ip address of the printer to diagnose further. How do we find IP address of a networked printer? There are a few different ways to go about finding it.
1. A network printer with built-in ethernet port usually provides a menu button that will allow you to display IP address assigned to it. You may also try printing self test or configuration page from your printer.
2. If you can't find an IP address of a network printer from the menu display or your printer is connected to a printer server with no display, you may find its address from any networked computer configured to use the printer. To find the printer IP address from a Windows machine, perform the following.
  • Start -> Printers and Faxes, or Start -> Control Panel -> Printers and Faxes
  • Right-click the printer name, and left-click Properties
  • Click the Ports tab, and widen the first column which displays IP address of the printers
3. If your networked printer uses DHCP, you may connect to your router and find the IP address of the printer from DHCP status page. The router displays all host machines that are assigned dynamic IP addresses.
4. You may also try pinging your network from a computer connected to the network, and lookup an arp table. On your computer, click [Start] -> [Run...] and type "cmd" and [Enter]. Type "ipconfig" to find your network address. The network address is found by performing a logical AND operation on your IP address and the subnet mask. For example, if you IP is 192.168.1.101 and subnet mask is 255.255.255.0, then the network address is 192.168.1.0. Ping your network using a broadcast address, i.e. "ping 192.168.1.255". After that, perform "arp -a" to determine all the computing devices connected to the network. One of the IP found is your networked printer.
5. You may also use "netstat -r" command to find an IP address of all network routes. However, if your printer has problem communicating with other network devices, you may not be able to find IP address of the printer using "netstat" command.
where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
Having trouble adding printer canon ir3300 thru ethnet connection. directly to laptop. This printer isn't on the current network. So, I'm not sure if I need to add it first. Can you please advise.
You will need to buy a "Crossover Ethernet Cable". A ordinary straight through ethernet cable will not work. When you connect the crossover cable the laptop will see it and assign an IP address as though it was on a network. You then need to create a standard IP Port. take a config printout and look for the ip address. Add a single digit one to the address and make that you std IP Port.
Install your network driver and it will look for the printer on your new network (your laptop and printer). providing it does then all should work ok.
Good luck.
Aug 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
where do i find the ip address for my lexmark z705 printer
This may help.
How do I find IP address of a network printer?
Thank you for choosing FixYa! have a good one!
Aug 05, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Computer cannot see Oki c5510 in network.
It's very possible that with a reboot of the printer and/or your router that DHCP assined a new IP address to the machine. Look in your router settings for the active clients and look for the IP address of the printer. Than go into your printer management within Windows, check the IP address assigned to the printer and change it to match the IP address you found on the router. It's happened to me before and it can be very frustrating.
Aug 08, 2009 | OKI C5510 MFP All-In-One Led Printer
4,250 people viewed this tip
jasbo
jasbo
