Tip & How-To about Apple iPod touch
How can I charge the battery of my iPod Touch?
Apple goes out of his way for most of its products easier to use. The iPod Touch is no exception. Load it requires only the USB cable and comes with access to a computer. The battery is not user, if your iPod does not charge you or a defective battery, which requires the device to an Apple reseller.
1. Turn on the computer. Let it boot completely before proceeding. If a laptop, connect it
2. Turn your computer into sleep or hibernation. On a Windows machine, you can do this by going to the Start menu, click "Control Panel" and select "System and Maintenance". Click the "Power Options" and click "Change Power Settings". Click the "Advanced Settings", select "Never" in the options for the "sleep after" setting. On a Mac, go to "System Preferences" and click on "Energy Saving" option. Check the box next to "Put the hard drive (s) to sleep when possible".
3. Connect the iPod to the USB cable. Connect the other end of the cable to your computer. Your iPod will automatically begin charging.
4. Turn off the iPod when it reports that it has completed loading.
Apple iPod touch Logo
plug my Ipod into the HDMI port and and unit shuts down with red light on the power switch fashing. Why
Hello there.
I presume you are using the correct adapter.....
The Apple Digital AV Adapter is compatible with the fourth generation iPod Touch
http://store.apple.com/us/product/MD098ZM/A/apple-digital-av-adapter
For Fifth generation ipod you need this
http://store.apple.com/us/product/MD826ZM/A/lightning-digital-av-adapter
Follow these steps carefully, it should work
http://techchannel.radioshack.com/can-use-hdmi-cable-ipod-touch-1020.html
The flashing red ??? You ARE connecting the iPod to some form of power aren't you ?
The steps in the above tell you to use a usb cable at the same time.
Sep 22, 2014 | Audio Players & Recorders
How do I charge my new iphone 16GB?
Your new iPhone comes with a USB cable and a wall charger in the box. If you don't have a computer, you can plug the wall charger to any socket in your house and connect your iPhone to the wall charger using the USB cable. However, if you have a computer, you can plug the USB cable to any USB slot from your computer and connect it to your iPhone.
You can also charge your device from any iPhone dock, or even those docks attached to your home theater system.
For more iPhone / iPod touch tips, click here.
Feb 12, 2010 | Apple iPhone (16 GB) Smartphone
What component needed
okay most ipod touches read as camera for some odd reason but most of the time ipods on read apple products
Sep 21, 2008 | Apple iPod touch
Ipod Touch
get on your laptop download itunes if you don't already have it... then connect your ipod touch to the usb port. After that itunes will come up... just follow the instructions... once all that is done... disconnect your ipod and start adding music to your itunes then connect your ipod touch again to load your music into your ipod.
Jun 21, 2008 | Apple iPod touch
1,002 people viewed this tip
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
