Tip & How-To about Apple iPod touch
How to Connect my Apple iPod Touch 8 GB to Internet
Apple iPod touch is a touch screen version of its popular iPod device, similar in appearance and function of the iPhone. Like the iPhone, iPod touch is able to access the Internet, although by different means. While the iPhone usually connect to the Internet via a wireless network operator's mobile data, the only way to connect to the Internet in an 8 GB iPod Touch is the device to use built-in wireless adapter.
1. Get references to a wireless network nearby, if you are not home or do not have access to a public network without a password. If you're in a cafe, for example, ask the cashier to use the network password and you should use to connect.
2. Tap your iPod Touch "Settings" icon and "Wi-Fi." If a blue button "off" appears next to the Wi-Fi, tap it on the wireless adapter to connect the device.
3. Scroll through the list of wireless networks will appear, and then tap corresponding to your network. Enter a password - if the network requires - and tap "Connect" to your connection to the Internet iPod touch 8 GB.
Apple iPod touch Logo
ipod touch is disabled
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your iPhone or iPod touch to your computer.
  3. Select your iPhone or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up. NOTE:For the iPhone only, after a restore, the iPhone displays the "Connect to Activate" screen. During this period you must continue to keep your device connected to complete activation and make sure you are connected to the internet.
  9. The final step is to restore your iPhone or iPod touch from a previous backup. So on the setup screen select the back up you want for your iPhone or iPod touch and select the Continue button in order to complete your device's restoration.
Aug 27, 2010 | Apple iPod touch
how do i undisable my ipod touch
Aug 24, 2010 | Apple iPod touch
Ipod touch will not come out of locked mode
Dec 18, 2009 | Apple iPod touch
My iPhone won't turn on! I've tried everything and I only get to the apple. HELP!
Try forcing an application to close
To force an application to close, follow these steps:
iPhone or iPod touch running iPhone OS 3.0 or later
  1. Press and hold the Sleep/Wake button until the red slider appears. When the red slider appears, release the Sleep/Wake button.
  2. Instead of dragging the red slider, press and hold the Home button for six seconds.
  3. If the device does not return to the Home screen, see the steps below to restart.
iPhone or iPod touch running iPhone OS 2.2.1 or earlier
  1. Press and hold the Home button for six seconds.
  2. If the device does not return to the Home screen, see the steps below to restart.
If the iPhone or iPod touch remains unresponsive, try restarting the device:
Restarting iPhone or iPod touch
  1. To turn it off, press and hold the Sleep/Wake button until the red slider appears.
  2. Slide your finger across the slider to turn off iPhone.
  3. To turn iPhone or iPod touch on, press and hold the Sleep/Wake button until the Apple logo appears.
If the iPhone or iPod touch remains unresponsive after trying the above steps or if it is in a different state, such as showing a persistent Apple logo on the display, try resetting the device:
Resetting the iPhone or iPod touch
Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds.
Hope this helps...
Sep 03, 2009 | Apple iPhone Smartphone
My itouch screen is responding to touch but not doing anything
I would restore the ipod touch using itunes. I have included step by step instructions below just in case you are unsure on how to do a restore.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
If this does not resolve your issue, you most likely have a hardware issue. If that is the case you may be able to get it repaired or replaced by apple for free depending on how old it is. I included the apple phone number below.
1-800-APL-CARE (1-800-275-2273) Good luck :)
Apr 24, 2009 | Apple iPod touch
640 people viewed this tip
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
