Tip & How-To about Apple iPod touch
How to save my battery of iPod
Some iPod users, the device is everywhere you go - in the car, work, go to the gym and everywhere in between. An iPod can play for several hours, but eventually must be recharged. Over time, the iPod's rechargeable battery wears out and needs replacing. There are several ways that the iPod's battery life to expand, if it is in use now and again all day, every day, or just for an hour or two. Caring for the battery can improve performance.
1. Control of the controls. Avoid a lot of fast forward, rewind and click "Next" and "Previous". The iPod to work harder, the faster the battery drains. Building playlists for working out, relaxing or traveling in the car to the temptation to jump in numbers to resist.
2. Off is not necessary. Apple recommends that iPod users to switch off the device backlight to conserve battery life. To accomplish this, go to Settings on the main screen and then "Backlight" and "Off". If the tie is not used, it can also be disabled. Again, choose "Settings" and then "Equalizer" and "Off". If it is in use, turn off the setting to "Flat". IPod models with Wi-Fi network using a spare battery. Use the "Settings" and select "General", "Network" and "Wi-Fi" to disable this feature.
3. Keep your iPod at room temperature between 32 and 95 degrees Fahrenheit. The ideal temperature is 72 degrees Fahrenheit or iPod at room temperature. If the device is placed under 32 degrees, warm it up before him. Let the iPod in direct sunlight or inside a car for long periods.
4. Press "Pause" or turn off the iPod off when not in use. Leaving the iPod unattended, but the execution is a quick way to lose the battery. Place the unit in pause or sleep on the play / pause button for two seconds. Once the iPod is in sleep mode, slide the switch at the top to "hold" position, to avoid calling.
5. Load if necessary. The iPod should be charged when empty, regardless of when it will be used next. No cost of a case or cover. Connect the device to a docking station or directly to a computer to charge and, if requested, all software updates. These upgrades include improvements to conserve battery power.
Apple iPod touch Logo
Iphone 5s Crashes
You can remove all settings and information from your iPhone, iPad, or iPod touch tapping "Erase All Content and Settings" in Settings > General > Reset.
To remove all content and settings from your iPhone, iPad, or iPod touch:
If you wish to recover the data again, ensure that you have an iCloud or iTunes backup and that it is up to date.
Tap Settings > General > Reset > Erase all Content and Settings.
When you select to "Erase All Content and Settings," the process can take from a few minutes to several hours. The time this process takes will vary by iOS device:
Devices that support hardware encryption: Erases user settings and information by removing the encryption key that protects the data. This process takes just a few minutes.
Devices that overwrite memory: Overwrites user settings and information, writing a series of ones to the data partition. This process can take several hours, depending on the storage capacity of your iPhone or iPod touch. During this time, the device displays the Apple logo and a progress bar.
Note: If possible, connect your device to a charger and leave it connected until the process is complete.
Feb 18, 2014 | Apple Cell Phones
my ipod nano has songs but no sounds
Step 1:
Since entering the marketplace and revolutionizing the way people experienced personal audio, Apple's iPod has become the unquestioned leader in MP3 players. Available in several different models and versions including the original iPod, iPhone, iPod Nano and iPod Touch the iPod allows people to listen to any number of songs with just the click of the button. However, as is the case with numerous electronics, certain iPod users encounter issues with their device, particularly sound issues. These issues range from buzzing sounds through the headphones to low volume quality to no sound at all. Fortunately, there are ways to attempt to remedy these sound issues.
Volume and Song Selection Oftentimes, those iPod users listening to heavier music (such as rock or hip-hop) will encounter a buzzing noise when playing their device at maximum or near-maximum volume. Try lowering the volume a bit, as this will most likely remedy your buzzing issues. Also, try playing a different song from a different artist at the same volume to ensure sound quality is optimal across the board. Check the Headphones Before attempting to diagnose an iPod's sound issues, ensure the iPod itself (and not the headphones) are the culprit for these sound issues. Do so by disconnecting headphones from the iPod and playing them on another device, such as another iPod, a PC or laptop. If the quality is still not optimal, the headphones (not the iPod) are likely the reason for low sound quality. Also try connecting an iPod to an iPod listening dock. If the sound quality is optimal, but not so when connected to headphones, that would also indicate headphones as the cause of low sound quality. b> Reset the iPod Sometimes, simply resetting an electronic device such as an iPod, digital cable box or video game system will remedy the solution, as it gives the device a chance to reboot. Try resetting the iPod to remedy whatever sound problem you may be encountering, whether it's no sound or less-than-optimal sound. Not all iPods are reset the same way, so consult the user manual (either paper form or through Apple.com support) to learn how to reset a particular type of iPod. Adjust Sound Settings If sound quality is less than optimal, including too much bass, not enough bass, poor acoustics or any number of other issues, try altering an iPod's system settings to correct the issue. Do so by going to the "Settings" key on the main iPod menu, then going to "EQ." From there, test certain settings to see if they may correct the iPod's issue. EQ settings allow users to set their music to a certain type of genre (in terms of how the music is delivered), as well as lowering bass, increasing bass and altering acoustics. b> Make Sure Headphones Are Fully Connected As simple as it sounds, sometimes the reason iPods have no sound at all is because their headphones become somewhat detached from the device. Such is the case with physical activities such as exercising or doing yard work. If no sound comes through the iPod, make sure the headphones are plugged in all the way to ensure the lack of sound is not a simple oversight. Consult Apple Support Whatever the sound issue, if iPod users have tried everything possible to remedy the problem with no results, they can call Apple support or visit an Apple retailer to help further diagnose the issue. The issue could be a simple fix or might be so severe that purchasing a new iPod is the best course to travel.
Feb 09, 2013 | Apple iPod nano 3rd Generation
the Ipod Nano 5th connects to my headphones through the D650 but no with sound. Only play/pause next track last track are controllable. The motorola S305 head phone does play sound from the phone so they are OK... IS the NANO the leading cause
i have the same problem with 5th gen nano and the D650. It pairs and i can use the controls but no sound comes to the headphones. I tried the headphones with the onboard bluetooth on my ipod touch and i had no problems. The problem only happens with the d650 and my nano. Someone has made this work im sure.
Jun 30, 2010 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Lost Or Stolen iPod? Help Please!
I would have a word with your tutor.
Mar 01, 2017 | Apple iPod nano MP3 Player
734 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
