Tip & How-To about Apple iPod touch
How do I Connect my iPod Touch to a Netgear WNR2000 Router
Netgear WNR2000, a wireless-N router, you can connect to the Internet without the hassle of cables. IPod touch supports Wi-Fi (wireless) connections. If you're within range of the router, you can connect to the wireless network. Once connected, enjoy a fast transfer speeds that allow you to quickly scroll pages and run the programs enabled network.
1. Connect the iPod Touch. Tap Settings on the Home screen settings of media player to start.
2. Scroll through the settings when you come to "Wi-Fi, tap to activate the feature. IPod touch detects networks in range.
3. Select the Netgear WNR2000 Wi-Fi network can include the name has been set, so it helps to know the name. If a secure network, enter the password. If you do not know the password, your iPod Touch cannot connect to the network. Once selected, your iPod automatically connect to the network. The Wi-Fi icon in the status bar at the top.
4. Select "ON" next "Ask to Join" if you want your iPod touch to ask you to connect to wireless networks within range.
Apple iPod touch Logo
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
705 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
