Tip & How-To about Computers & Internet
How do I make my iTouch Louder
He the volume of the iPod Touch can be affected in some way, the definition of musical sound check the volume limit set in the settings device preferences. The tool of sound check, which can also be found on iTunes, check your iTouch music and video library for the stabilization of the equalizer song for a constant level, the volume limit reduces the volume to grow beyond a set point, which helps the potential adverse effects of hearing loss caused by loud music.
1. Press the button to the left of the iPod Touch. The volume switch top left of the iPod Touch increases the sound volume, and gives a volume icon on the screen as it grows. Accident on the volume button for the iTouch, it seemed sound problems. Touch the "Music" icon to start playing the song, press the volume for music to grow.
2. Adjust the volume control settings. Tap Settings on the iPod screen Touch, Touch "Music" and tap "volume limit." Slide the tab to the right of way to reduce the volume bar to change the limit of the maximum. Press the Home button to save and Settings.
3. Sound Check off. Tap "Music" in the Settings window and slide the guide Sound Check to the left to the sound check feature off. A Sound check song keeps playing very hard at the same level. While the function prevents sudden jumps in volume, can also lead to a series of songs to play very soft, depending on the quality of the music.
4. Adjust the volume to your headphones. Press the "+" button on your Apple headphones, the volume of a music or video playback to increase. If a song or video does not play, the volume control adjusts the volume on the iTouch.
Computers & Internet Logo
7th generation ipod nano has no sound
Hi Katherine
Try this solution to your problem...
Turn on Ipod, on the left hand side there is a volume
control switch. While you are on a song, hold the top of the
volume control switch to increase the volume.
If that does not work then go to "Settings". then
"music" and make sure your "Volume Limit" is
set to "Off", if it is not then touch "Volume Limit" and set it
to "Off"
Please do not forget to rate me
Bud
Oct 29, 2012 | Apple iPod classic 7th Generation
volume wont turn up
Resetting the volume limit on your iPod Nano affects everything you listen to, from music to audio books. You can adjust the volume for each individual item on your Nano using the click wheel, but the highs and lows of the sound will depend on the overall volume limit setting. Volume levels will vary with different ear buds and headphones, and using external devices like docking stations to play your iPod Nano will also cause variation in the volume.
Instruction:
1 Press any button on your iPod Nano's click wheel and turn it on. Press the "menu" button at the top of the click wheel until you reach the iPod menu.
2 Select "Settings" from this menu by scrolling down until "Settings" is highlighted, then click the center button.
Select "Playback" from the menu choices that show up.
4 Select "Volume Limits." You will reach a screen with a speaker icon and dots indicating the level of volume your iPod is currently set on.
5
Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Goodluck
Dec 10, 2011 | Apple iPod nano
volume wont turn up on my mp3 - volume too low
How to Reset the Volume Limit on the iPod Nano
Instructions
3 Select "Playback" from the menu choices that show up.
5 Scroll the wheel up or back to adjust the volume limits. Press the center button and you will have the option to lock in your settings by selecting a four-digit combination lock. This is not a necessary step; you can click on "done" and finish. Setting the combination allows you to have more control over any future changes to your iPod's volume limits. Scroll the click wheel to select your combination. Press the center button and you will revisit the volume limits; adjust it as you like and press the center button.
Tips & Warnings
If you set up a combination and forget it, you can reset your iPod Nano and start over again. Resetting will not lose any of your downloads, but you will need to restore or reset many of the settings you initially chose when you first set up your iPod.
Changing the volume limits on your iPod Nano covers everything on your player, but the sound levels for songs, audio books and shows will vary based on how they were recorded.
i got his ipod touch 1st gen. on the internet and everything worked except for the sound on the music but i figured out tht i could her the sound faintly but i cant get it to turn up.....ive tried the general settings and everything and no volume slide either
Since you got this from the internet I think the person you bought it from might be messing with you. On the iPod touch it is possible to limit how loud music is played, and a prankster might do this to you. To check if they did this:
  1. On your iPod, go to the Settings app.
  2. Scroll down to "Music."
  3. Choose "Volume Limit"
Here is where you would be able to find out if there is a volume limit on your iPod. If they didn't lock it then you can slide the volume slider all the way to the right, but if they did lock the volume, you have to go to option 2.
Option 2 is to restore it with iTunes. And this will fix just about anything that goes wrong with your iPod.
  1. Plug your iPod into iTunes and sync it.
  2. On the sidebar on the left, click on your iPod and go to the summary tab.
  3. Click on restore and let iTunes do its thing.
  4. After it is restored you should be able to put all of your music back on it and hopefully the iPod will be fixed.
May 10, 2011 | Apple iPod touch 1st Generation (8 GB) MP3...
very low volume on a brand new ipod touch what should i do to fix this problem
Turn on Ipod, on the left hand side there is a volume control switch. While you are on a song, hold the top of the volume control switch to increase the volume.
If that does not work then touch "settings", then touch "music" and make sure your "Volume Limit" is set to "Off", if it is not touch "Volume Limit" and set it to "Off".
May 16, 2010 | Apple iPod touch Second Gen (8 GB,...
1,762 people viewed this tip
David Payne
David Payne
