Tip & How-To about Computers & Internet
How to Troubleshoot my iHome iP97
You can use your iPod or iPhone to listen to music while traveling. When buying an iPod dock, iHome iP97 like, you can connect your iPod or iPhone and listen to your music through a system of built-in speaker. IP97 to use, connect the bottom of the device at the entrance at the top of the system. If you have technical problems with its iP97, you can resolve to try some troubleshooting steps.
1. Unplug the power cord from the back of the unit and reconnect as the iP97 will not turn on when you press the button "Power". Make sure the other end of this cable is connected correctly. If you still cannot connect, try connecting the cable to another outlet. If it is enabled, the faulty exhaust.
2. Remove your iPod or iPhone from the dock and check the connections on the device and the iP97 to dirt or obstacles to the pier is on but does not respond to the button. Replace the device in the dock. If it still does not respond, remove the device, unplug the power cord to the iP97, open the battery compartment at the bottom of the device and remove the two backup batteries. Let the unit sit for an hour to replace.
3. Open the battery compartment and remove the backup battery when the "Battery Low" error message. This means that the backup batteries are low or empty. Replace the batteries with two new AA batteries and put them back in iP97 using the "+" and "-" symbols printed on the inside.
4. Use the volume buttons on the iP97 to increase the volume when the iPod or iPhone is connected and playing music, but you cannot hear. Adjust the volume on your iPod or iPhone, if you still hear the sound. In order to achieve a comfortable volume level, you have the volume on both devices.
Computers & Internet Logo
Cheap iPod touch, iPod Nano, ipod Classic/shuffle, Discount iPod Conversion/Ripping softwares for Black Friday 2009
Thanks for the recommendations. I think the best place to buy cheap ipod accessories is definitely online.
Nov 25, 2009 | YouTube Videos
My iphone 3GS is not been charging when I dock in JBL On Time 200P and it used to charge just fine. This happened after I used in a travel a hotel iHome as my charging dock, and then a wall charger for iPhone (usb). What can I do to fix this? Thanks
It seems an issue of the dock connector of your Iphone, please check if there's no contact blocked or bended, if there's one or more contacts with these conditions, you may need to replace the dock connector of Iphone.
Feb 24, 2011 | JBL On Time Docking Station for Apple iPod...
new ipod, old ihome. "device not supported" Any way around?
I'm sorry but no. the ihome is only for the 1st generation, so if you want to use it with your new ipod, you need to buy another one that supports second generation. this is a bummer, but its how they make their money.
Jul 28, 2009 | Apple iPod touch Second Gen (8 GB,...
364 people viewed this tip
David Payne
David Payne
