Tip & How-To about Computers & Internet
How do I make my iPod always Sync my Photos
If you have an iPod capable of storing photos, you probably want to keep the images. To ensure that your photos are always sync your iPod, your synchronization settings in iTunes. If you choose to have your iPod to sync automatically or manually, your preferences under "Photos" tab to sync photos from a folder or program. When you set these preferences, iTunes will remember them and sync your iPod the same way you connect to your computer.
1. Connect your iPod to your computer using the data cable that came with it.
2. Open iTunes if it does not open automatically. Click the name of your iPod under "Devices" in the left pane.
3. Click on "Photos" above the central panel of iTunes.
4. Check the box next to "Sync Photos." Select a program or a folder with the photos you want to sync from the drop-down menu.
5. Choose to sync all photos and albums or just selections. If you choose the latter, make your selections by checking the boxes next to the folders to sync. You can also choose to automatically include certain events, or events such as the latest in recent months.
6. Click Apply. Now, when you sync your iPod, it will always sync your photos.
Computers & Internet Logo
charger ipod model a1199
http://www.everymac.com/systems/apple/ipod/specs/ipod-2nd-generation-nano-specs.html
USB Support:
Sync & Charge
Firewire Support:
Charge Only
Details:
The second generation iPod nano models are capable of charging and syncing by USB via the dock connector. It also can charge, but not sync via Firewire "400".
Connectivity:
USB
Ports:
Dock, Headphone*
Details:
Apple reports that this model provides "USB through dock connector."
*Ports include the "dock connector [and] stereo minijack".
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=9C41186E7131E6658B9324CCA
Aug 05, 2013 | Computers & Internet
How do i transfer my pics frm my laptop on my ipod touch pls advise
Transferring photos from PC to iPod touch is not that difficult. iCloud and iTunes can both be helpful.
Using "Photo Stream" to sync photos automatically with iCloud is pretty convenient. Go to "Settings > iCloud > Photos (Photo Stream on iOS 6)" and then turn on My Photo Stream. Then get your iCloud started on your PC. In the iCloud Control Panel, Check the "Photos" and then enable the "Photo Stream" option. After that, import the photos into the "Photo Stream" folder on your PC, and then you will be able to view the photos on your iPod touch. Using iCloud to transfer photos from PC to iPod touch is easy, but this method needs Wi-Fi connection. Only over Wi-Fi connection can iCloud sync photo on PC with iPod touch.
transfer-pics-frm-laptop-ipod-oxaxc0rwhkhzilrwacqreyis-3-0.png Using iTunes to sync photos with iPod touch is also easy. But you should be very careful of the syncing function of iTunes because it is a double-edge sword. Once wrong click, you may lose data in your iPod.
1. Plug your iPhone into computer via the USB cable. Launch iTunes if it doesn't launch automatically.
2. Find "File" option on the upper left corner. Then click "Add File to Library".
3. Select photos from your PC and then iTunes will sync the photos to iPhone automatically.
http://www.leawo.org/tutorial/how-to-transfer-photos-from-pc-to-iphone.html
Jul 06, 2010 | Apple iPod touch
Ipod will not Sync with photos
What error do you get?
Jan 04, 2008 | Apple iPod nano
290 people viewed this tip
David Payne
David Payne
