Tip & How-To about Computers & Internet
How to make a software update for iPod touch
Apple releases software patches frequently and security updates for its iPod portable music players, so it's a good idea to occasionally check the available downloads. Apple is updated downloads from iTunes media application. Once the device is connected to your computer, you can access your iPod touch using iTunes and check for updates that can be applied to the device.
1. Connect your iPod touch to your computer through the USB cable that came with the device.
2. Run the application iTunes.
3. Click the item to your iPod touch device from the menu on the left of the iTunes program window.
4. Click the "Summary" tab at the top of the window and click "Check for Update". iTunes will check for and install software updates for your iPod touch device.
Computers & Internet Logo
when I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
my ipod will not turn on
Find out what to do if your iPod won't turn on.
Several things could prevent iPod from turning on. Check each cause in this order to find out what's wrong.
Products Affected
iPod
Resolution
Make sure the Hold switch is off
1. Check to see if the Hold switch is on. It's located on the top or the bottom of iPod. When it's in the on position, you'll see an orange patch.
2. To turn the hold switch off, slide it until you no longer see the orange patch.
3. Press any button to turn on iPod.
iPod hold switch on iPod hold switch on
Make sure the battery is charged
iPod won't turn on if the battery is empty. Instead, a low battery screen appears for about 3 seconds when you try to turn it on.
iPod battery empty icon
To charge your iPod, connect your iPod to your computer's built-in 6-pin FireWire or high-powered USB port or connect it to the Apple iPod Power Adapter and plug the power adapter into an electrical outlet. Note: iPod models without a Click Wheel cannot be charged via USB. iPod shuffle requires a high-power USB port to charge. iPod nano and iPod (5th generation) can charge via USB or FireWire, but they require USB to sync with iTunes. If you're not sure what iPod model you have, click here.
If you are connecting via USB and the battery is completely discharged, there may be up to a 30-minute delay before iPod powers up. Click here for more information.
Reset iPod
If iPod still does not turn on or appears to be "frozen" you may need to reset it. When you reset iPod all your songs and files are saved. Some customized settings may be lost.
Let the iPod battery drain
In rare cases, iPod might get into a state in which it needs to be drained completely before it can be reset. If iPod didn't turn on after you reset it, follow these steps:
1. Disconnect iPod from all power sources and leave it disconnected for about 24 hours.
2. Reconnect iPod to the Apple iPod Power Adapter or computer and reset it.
Update iPod's software
If iPod turns on after you reset it, use the latest version of iTunes to update iPod.
Additional Information
If you have tried the solutions above and iPod still won't turn on, check the following:
* Make sure iPod is the only device in your FireWire or USB chain. Disconnect everything but the mouse, keyboard, and your iPod, then see if it will turn on.
* Make sure you are using the FireWire or USB cable that came with your iPod, and that the cable is in good condition.
* Try connecting iPod to the built-in port of a different computer to see if that works. Note: If using a portable computer, make sure it is plugged in to a power source and that the lid or display is open. If the lid is closed the computer may go into either standby, sleep, or hibernation mode and iPod will not charge properly.
If you still can't turn iPod on after performing these steps, it may need to be repaired. You can arrange for repair at the iPod Service Website.
iPod may not power on, may be stuck on the battery logo, or may have stopped responding while playing music (in which case the Click Wheel doesn't respond).
Products Affected
iPod classic (120GB), iPod nano, iPod classic, iPod classic 160GB (Late 2009), iPod (5th generation), iPod (5th generation Late 2006)
Resolution
If you experience any of the above issues, try the following steps:
1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
* If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
* If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
6. Try putting the iPod into disk mode.
* While in disk mode, connect the iPod to iTunes and try to restore.
* If the iPod is still not recognized by iTunes, the iPod should be serviced.
See http://www.apple.com/support/ipod/ and click the Service tab for more information about your service options.
Hope it helped...
May 21, 2011 | Sony NWZ-E436F MP3 Player
how can i download music to my ipod touch without
Unfortunately Apple products are very proprietary, and Apple works very hard to keep people from using other software. I've seen several programs that you can purchase from places like Best Buy that replace the iTunes music software, but using that software will leave you unable to sync any applications or software updates. Good luck!
Oct 05, 2009 | Apple iPod touch
iPod shuffle Second Gen problem
Apple recommends that iTunes customers using Windows Vista upgrade to iTunes 7.2 or later. If you are using an iPod with iTunes on Windows Vista, please review the important information in Knowledge Base document
Ejecting iPod using Windows Explorer on Windows Vista may corrupt iPod
Issue
Some customers may see the following message when connecting an iPod to iTunes 7.2 or later on a computer running Windows Vista.
Solution
Microsoft has released an update for Windows Vista that addresses a situation where ejecting iPod from Windows Explorer or by using the "Safely Remove Hardware" feature in Windows Vista could corrupt your iPod. Apple recommends Windows Vista customers who own an iPod install this software update. For information on how to install this Microsoft hot fix, refer to the "Update your software" section below. Tip: iPod can always be ejected safely by choosing Eject iPod from the Controls menu within iTunes.
Microsoft has made this Update for Windows Vista (KB936824) available via Windows Update as well as a separate download package. To download this update via Windows Update follow the steps below:
  1. From the Start menu, choose Control Panel.
  2. In Control Panel, select Check for updates in the Security section. If the Control Panel is in Classic view, open Windows Update.
  3. Click the View available updates link and be sure that Update for Windows Vista (KB936824) is checked.
  4. Click Install.
Sep 15, 2007 | Apple iPod shuffle Second Gen. Silver (1...
iPod Nano startup
Have you tried The Famous 5 Ipod R's? " 1. Reset your iPod, iPod nano, iPod mini( http://docs.info.apple.com/article.html?artnum=61705 ), or iPod shuffle ( http://docs.info.apple.com/article.html?artnum=300595 ). 2. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB). 3. Restart your computer, and make sure that you have the latest software updates installed. 4. Reinstall your iPod and iTunes software. You can download the latest versions of iPod Updater (http://www.apple.com/ipod/download/ ) and iTunes (http://www.apple.com/itunes/download/ ) from our website. 5. Restore your iPod using the latest iPod Updater. Important: Please note that restoring (http://docs.info.apple.com/article.html?artnum=60983 ) an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again. Watch the Five Rs performance in action! (http://www.apple.com/support/ipod/tutorial/ip_gettingstarted_t16.html) " Did it help any? Good luck!
Jun 24, 2006 | Apple iPod nano
209 people viewed this tip
David Payne
David Payne
