Tip & How-To about Computers & Internet
How to Get my iPod Touch going again when It Crashes
The iPod touch now and then dealing with large volumes of data, and it can sometimes freeze or crash, giving you a blank screen or frozen. There are three simple steps to restore your iPod to normal. You can reset the iPod, which only puts the iPod on and off. You can use your iPod, which is how to restart the computer. If none of these options work, you can restore your iPod, which it returns to factory settings.
1. Press the "Sleep / Wake" button at the top of the iPod touch for about eight seconds. The red slider appears. Pass the slide bar to the iPod off. Wait about 15 seconds, press and hold the "Sleep / Wake" button until the Apple logo appears, the iPod back on. If the iPod is set, you can stop here.
2. Hold the "Sleep / Wake" button and the "Home" button at the same eight seconds, or until the Apple logo. The "Home" button at the bottom of the windshield. This is the iPod. If this solves the problem, you can stop here.
3. Connect your iPod to your computer via the USB docking. Open iTunes and click the name of your iPod under "Devices" on the left side of the window. Click the "Summary" tab at the top of the center panel.
4. Click "Check for Updates" to see if the iPod does not need new software. Select to download and install the update if necessary.
5. Click "Restore". Choose to back up the iPod in the box that appears, follow the instructions to restore.
6. Select your iPod back up on the screen that appears when the restore is complete. Choose your last backup; it will configure your iPod as it was before the accident.
Computers & Internet Logo
Ipod disabled
Like all electronic devices, iPods sometimes freeze and become unresponsive.
Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working.
All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated.
An iPod will appear frozen and unresponsive if this feature is activated.
A lock symbol will appear on your iPod's screen if it is in Hold mode.
Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button.
Press both buttons at the same time and hold them for up to 8 seconds.
Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen.
Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod.
Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it.
Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons.
Connect your iPod to its powerblock or a computer if it is still frozen.
Wait 5 minutes and then try to reset it.
Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again.
May 15, 2013 | Audio Players & Recorders
My ipod touch 4th generations says ipod disabled connect to itunes, but screen is locked
Like all electronic devices, iPods sometimes freeze and become unresponsive. Sometimes iPods lock up when they're dropped on the ground or come in contact with water, but less destructive accidents may also cause them to stop working. All versions of the iPod have a way to reset their hardware should they stop playing music or refuse to turn off.
Check the "Hold" switch on the top case of your iPod to be sure it isn't activated. An iPod will appear frozen and unresponsive if this feature is activated. A lock symbol will appear on your iPod's screen if it is in Hold mode. Switch the "Hold" button on and off once. Place one finger on the "Menu" button and another on the center button. Press both buttons at the same time and hold them for up to 8 seconds. Release the "Menu" and center buttons once the Apple logo appears on your iPod's screen. Try releasing the buttons and pressing and holding them a second time if the logo does not appear, as it can sometimes take several tries to reset a severely frozen iPod. Press and hold the top button and the center "Home" button on a frozen and unresponsive iPod touch to reset it. Hold the buttons for at least 10 seconds and wait for the Apple logo to appear on the screen, then release the buttons. Connect your iPod to its powerblock or a computer if it is still frozen. Wait 5 minutes and then try to reset it. Sometimes an iPod can appear frozen when its battery runs out and just needs a few minutes of power to start working again. Hope this helps.
Jan 19, 2013 | Apple iPod touch 4th Generation MP3 Player
How do I fix my frozen e reader
Jan 19, 2013 | Apple iPod touch 1st Generation (8 GB) MP3...
Why Samsung Galaxy S keeps freezing and crashing. Like 5 times a day. Sometimes it is just me wanting to open up a application or just in the middle of texting. What is happening?
You should backup your contacts and perform a reset on the phone.
First, try this:
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password, then tap Yes to confirm
If that doesn't work, or if your phone is frozen:
  1. Turn the power off. If your Samsung Galaxy S is frozen, pull the battery out and reinsert it
  2. Hold the Volume Down button
  3. Press and release the Power button
  4. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  5. Select Clear Storage by pressing the Volume Down button
  6. Press and release the Power button
  7. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
If you selected YES, all data including third-party applications will be deleted from the Samsung Galaxy S. Once the wipe is complete, the phone will reboot to its factory fresh state.
Aug 09, 2011 | Samsung Galaxy S GTI9000 Smartphone
ipod touch frozen
Try this
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
But you will lose all your data and you will have to jailbreak it again.
Sep 18, 2009 | Apple iPod touch
210 people viewed this tip
David Payne
David Payne
