Tip & How-To about Computers & Internet
How do I Download WiFi on my iPod Touch
Apple iPod touch comes with several features that distinguish it from other iPod devices, namely the touchscreen navigation interface. Another unique possibility for the iPod Touch on iPod is the device built-in wireless adapter, allowing you to make the Web browser, e-mail and web-based mobile applications. Internet access to an iPod Touch you need to download anything, but to connect the wireless adapter and search for networks.
1. Connect your iPod Touch or if it is already connected, touch iPod touch "Home" button to return to "Home" screen. Touch the "Settings", indicated by a series of gears of silver.
2. Tap "Wi-Fi." Touch the white "Off" to switch wireless adapter box. If a blue button "On", then your wireless is already enabled.
3. Scroll through the list of wireless networks that appears, and play what you want. Password input of the network, if necessary, and tap "Join".
Computers & Internet Logo
what generation this iPod is serial number 1A009QC075J
iPods come in a variety of generations and models, including the nano, Classic and Touch. Depending on your model you may be able to record video, play games or watch television.
If you're unsure of your device's model, you can determine which iPod you have by using your serial number.
After determining your model, you can find out which features and capabilities your iPod has.
Go to Apple's official website (see Link Below) and click the Support tab.
http://www.apple.com/
Click the Online Service Assistant link, which is located in the Support Services menu on the right side of the screen.
The Service and Repair page will open.
Find your iPod's serial number.
This is engraved somewhere on the back of your iPod, either on the body of the device or on the clip.
You can also find it in your iPod's About screen by clicking Settings and selecting About (or General followed by About on an iPod Touch).
Enter your iPod's serial number and click the "Continue" button.
Your iPod model and generation will be displayed at the top of the screen.
http://support.apple.com/kb/HT1353
also
With each new generation of the iPod Touch, you get new features and updates to the older generation.
The 2nd and 3rd generation iPod Touches are very similar in physical appearance.
The easiest way to determine what generation of iPod Touch you have is to check the model number on the back of the device.
The 2nd and 3rd generation iPod Touches were given unique model numbers to help distinguish your device generation.
Remove any protective case from the iPod Touch so you can see the back of the device.
Locate the model number at the bottom of the back of the device.
Check the model number against the following model numbers.
Third generation iPod Touches are model number "A1318." Second generation iPod Touches are model number "A1288."
Identifying iPod models
http://support.apple.com/kb/ht1353
Aug 10, 2013 | Apple iPod touch
my ipod is disabled and says connect to itunes but it also says itunes could not... so what do i do?
Step 1:
Apple's iPod Touch comes with a screen lock feature that allows you to set a four-digit security code to prevent others from using your iPod. Every time the iPod locks, you must enter this code to unlock the screen and access the user interface. Entering the wrong code too many times, or simply forgetting your security code, can cause you to be completely locked out. When this happens, you can quickly unlock your iPod Touch.
Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked. If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding. In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore." When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore." After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel. Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration. iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Mar 01, 2013 | Apple iPod touch Original
got locked out i pod touch
How to Unlock a 16GB iPod Touch
Instructions
1Connect your iPod Touch to the computer you usually sync it with. When you disconnect your iPod, it should now be unlocked.
2 If Step 1 does not work, you have to restore your iPod Touch. Be advised that restoring your iPod Touch returns it to the original factory settings. This means that all your songs and files will be deleted and lost. You can resync your files to your iPod from iTunes once you have finished restoration. Connect your iPod to your computer and open iTunes. Make sure you have the latest version of iTunes before proceeding.
3 In the left navigation panel in iTunes, select your iPod under the "Devices" section. Click the "Summary" tab and select "Restore."
4 When iTunes prompts you about backing up your data, click "Back Up." In the following window, click "Restore."
5 After the restore process completes, you will see the Apple logo on the screen of your iPod. Leave your iPod connected to your computer until it shows up again on the iTunes navigation panel.
6 Your iPod touch is now unlocked. In iTunes you will be able to setup your iPod. Select the backup you made in the drop-down menu to restore your data files. Click "Continue" to finish the restoration.
Tips & Warnings
Apple notes that the company will not be able to help you unlock your iPod if you forget the security combination. Your only choice is to restore the device to the original factory settings.
Dec 05, 2011 | Apple iPod nano
244 people viewed this tip
David Payne
David Payne
