Tip & How-To about Computers & Internet
How do I update my iPod Touch updated to 3.2
Apple iPod Touch is a touch-screen iPod that contracts with the iPhone and iPod parts. To update the iPod Touch, iPod Touch you have to program a computer running iTunes 3.2. Update the iPod Touch is free and takes only minutes.
1. Connect the iPod Touch to your computer using the USB cable that came with the iPod Touch.
2. Let iTunes opens automatically when the iPod Touch is connected to the computer.
3. Click the name of the iPod on the left side of the screen. If the iPod does not have a name, it will read "iPod".
4. Click "Sync" in the lower right corner of the iTunes program. Disconnect the iPod Touch during the synchronization process. Progress, looking at the status bar at the top of the iTunes program.
5. Disconnect the iPod Touch as the synchronization is complete. You said that the synchronization is complete by reading the status bar at the top of the iTunes program. He will tell you that it is now safe to turn off your iPod Touch.
Computers & Internet Logo
ipod touch is disabled
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your iPhone or iPod touch to your computer.
  3. Select your iPhone or iPod touch when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed the iPhone or iPod touch restarts and displays the Apple logo while starting up. NOTE:For the iPhone only, after a restore, the iPhone displays the "Connect to Activate" screen. During this period you must continue to keep your device connected to complete activation and make sure you are connected to the internet.
  9. The final step is to restore your iPhone or iPod touch from a previous backup. So on the setup screen select the back up you want for your iPhone or iPod touch and select the Continue button in order to complete your device's restoration.
Aug 27, 2010 | Apple iPod touch
how do i undisable my ipod touch
Aug 24, 2010 | Apple iPod touch
Ipod touch will not come out of locked mode
Dec 18, 2009 | Apple iPod touch
how to sync .ipa files from comp to iphone thru itunes ?
when you sync the iPhone with the computer, iTunes will only add what is new, it will not delete your apps.
Setting Up Syncing You use iTunes on your computer to set up which items are synced. Make sure you have the most recent version of iTunes (On a PC, open iTunes and choose Help > Check for Updates. On a Mac, open iTunes and choose iTunes > Check for Updates.
Step 1: Connect iPhone or iPod touch
  1. Connect iPhone or iPod touch to your computer using the included cable. You can connect the cable from your computer directly to iPhone or iPod touch, or connect the cable from your computer to the Apple Universal Dock (available separately) and put iPhone or iPod touch in the dock. By default, iTunes opens automatically.
  2. Select iPhone or iPod touch in iTunes under Devices on the left hand side and click the Info tab.
Step 2: Set Up Which Items Are Synced Click the respective tabs in iTunes to specify which media and information you want synced from your computer to iPhone or iPod touch.
For more information about syncing iPhone with your computer see the iPhone User's Guide:
On your computer: click here to download and view "Chapter 1: Getting Started" in iPhone User Guide.
On iPhone: Tap Safari and view http://help.apple.com/iphone/guide/.
For more information about syncing iPod touch with your computer:
On your computer, click here to download and view "Chapter 1: Getting Started" in iPod touch User Guide.
On iPod touch: Tap Safari and view http://help.apple.com/ipodtouch/guide/.
Step 3: Sync iPhone or iPod touch Click Apply in the lower-right corner of the screen. Your computer syncs with iPhone or iPod touch according to your settings.
The first time you sync iPhone or iPod touch, you are asked if you want to merge data, replace data on the service, or replace the data on your computer. After that, anytime you connect iPhone or iPod touch to your computer, iTunes opens and syncs with iPhone or iPod touch according to your settings.
You can adjust sync settings anytime iPhone or iPod touch is connected to your computer. You can only connect and sync with one iPhone or iPod touch at the same time. If you need to sync more than one iPhone or iPod touch, disconnect one before connecting the other.
Note: Syncing won't delete any contact in Yahoo! Address Book that contains a Messenger ID, even if you've deleted the contact from your address book on iPhone or your computer. To delete a contact containing a Messenger ID, log in to your Yahoo! account online and delete the contact using Yahoo! Address Book.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 01, 2009 | Apple iPhone Smartphone
My itouch screen is responding to touch but not doing anything
I would restore the ipod touch using itunes. I have included step by step instructions below just in case you are unsure on how to do a restore.
Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPhone or iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPhone or iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPhone or iPod touch settings are restored to their factory condition.
Whenever you restore your iPhone or iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPhone or iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPhone or iPod touch to your computer. Select your iPhone or iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPhone or iPod touch's settings before restoring, select the Back Up option (as seen in the image below). If have just backed up the device, it is not necessary to create another.
If this does not resolve your issue, you most likely have a hardware issue. If that is the case you may be able to get it repaired or replaced by apple for free depending on how old it is. I included the apple phone number below.
1-800-APL-CARE (1-800-275-2273) Good luck :)
Apr 24, 2009 | Apple iPod touch
262 people viewed this tip
David Payne
David Payne
