Tip & How-To about Computers & Internet
How Do I program my iPod Touch
Completely reprogram your iPod touch by performing a "Restore". Do not let the name fool you, Apple's restore feature restores the original factory settings, so the iPod unit is clean, except for the operating system. Access to restore utility in iTunes. If your iPod is frozen or stopped working, first manually reset, and then restore in iTunes.
1. Hold the "Sleep / Wake" button and the "Home" button at the same time as your iPod is frozen or unresponsive. Holding the button until the display converts the iPod Touch in recovery mode.
2. Press the "Home" with one hand while you connect your iPod to your computer with disabilities with the other. ITunes will ask you to restore your iPod in recovery mode.
3. Click "OK" to start the recovery process. When iTunes is finished, your iPod Touch is completely reset, ***** except for the original operating system, and ready to reload with new data.
4. Connect the iPod Touch directly to your computer as usual, a restore point to start, without going into recovery mode. Open iTunes if it does not open automatically.
5. Click the name of your iPod under Devices in the left pane of the iTunes window. "Summary" tab open.
6. Look for the "Restore" button to the center of the window. Click this button.
7. Confirm that you want the iPod Touch to its original factory settings. This is your last chance to change his mind.
8. Wait until iTunes has finished. The iPod is restored to its original factory settings.
Computers & Internet Logo
how to enable a disable ipod touch
In order to enable your disabled iPod Touch, you'll have to completely reset it. Turn off the iPod Touch and when it turns back on the first thing to appear will be an Apple logo. Connect the iPod Touch to the computer it is paired with when this logo appears. Once it appears in iTunes, choose the "Restore" option and that will update the software and restore the iPod Touch.
Jul 18, 2011 | Apple iPod touch
apple ipod touch
font.f1 {font: 12.0px Times} Hello and thanks for contacting FixYa Technical Support.
Unfortunately, if you cannot recall the Passcode for your son's iPod Touch, then you will have to restore the iPod Touch.
The good thing about a restore however, is if you have previously synced the iPod Touch,when a restore is performed, all the data will be wiped from the iPod, BUT, the most current back up of when you last synced your iPod Touch will restore all the data back to the iPod.
I am providing an article from Apple Support, on how to restore your iPod Touch.
Restoring the iPod Touch
This will be the only way to restore access to the iPod Touch as well as create a new passcode.
I hope this helps.
Regards,
-Mactechtrainer
Apr 28, 2010 | Apple iPod touch
My apple Ipod Touch is fully charged but will not display any of my music I downloded Screen stays blank, shows no data or anything cnnot get it to sync either
    Complete a Regular Restore
  1. Back up your iPod Touch's data to your computer before the restore to prevent losing data. You'll need to reinstall it after the restore process.
  2. Connect to the Internet and install the latest version of iTunes from the Apple website.
  3. Make sure your iPod Touch is connected to your computer.
  4. Pick "iPod Touch" in the Source pane of the iTunes program.
  5. Click on the Summary tab.
  6. Choose "Check for Update."
  7. Select "Restore" and follow the instructions to finish restoring your iPod Touch. Complete an Advanced Restore
  8. If following the steps in the previous section did not work, follow these steps to perform an advanced restore. Turn off the power on the iPod Touch.
  9. Plug the iPod Touch into your computer.
  10. Power on the iPod Touch.
  11. Press the "Home" and "Sleep/Wake" buttons together for 5 seconds until the Apple logo appears.
  12. Release the "Sleep/Wake" button but continue holding down the "Home" button. The iPod Touch should reboot, and iTunes will notice the iPod Touch in recovery mode.
  13. Return to the above section and follow those steps to restore your iPod Touch.
Sep 24, 2009 | Apple iPod touch
Less Memory than my Ipod is Supposed to Have
You should start by restoring the iPod Nano and iPod touch using iTunes. Below is a step by step for both. This should resolve sync and capacity issues. If for some reason you have any further issues with these iPod's or this particular issue, please do let me know. I am eager to be of assistance :)
--------------------------------------------------- Last Modified: February 16, 2009 Article: HT1414 Old Article: 305744 Using the Restore function for your iPod touch is part of standard troubleshooting procedure. Restoring your device will erase all data from your iPod touch, including songs, videos, contacts, photos, calendar information, and any other data. All iPod touch settings are restored to their factory condition.
Whenever you restore your iPod touch, Apple highly recommends that you perform a sync prior to restoring in order to back up any changes since your last sync. If you have movie rentals on the device, see this document before restoring.
Use the following steps to restore your iPod touch:
Make sure you have the latest version of iTunes installed and running before attempting to update. Connect your iPod touch to your computer. Select your iPod touch when it appears in iTunes under Devices. Select the Summary tab. Select the Restore option. When prompted to back up your iPod touch's settings before restoring, select the Back Up option. If have just backed up the device, it is not necessary to create another.
Select the Restore option when iTunes prompts you (As long as you've backed up your device, you should not have to worry about restoring your iPod touch).
Once the restore process has completed the iPod touch restarts and displays the Apple logo while starting up
How to restore iPod with click wheel (ARTICLE NUMBER HT1339)
Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are: Restore Option
1: Restore - Restores with same iPod Software version already on iPod. Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option
3: Use Newest Version - Restores with the latest iPod Software available. Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apr 22, 2009 | Apple iPod touch
265 people viewed this tip
David Payne
David Payne
