Tip & How-To about Computers & Internet
How can I get a Wi-Fi for iPod touch?
Make a network connection Wi-Fi in the Settings menu of your iPod touch. Touch can connect to any open wireless network, or to closed networks as the password. If you're within signal range of your wireless network, tap the Settings icon for a network connection Wi-Fi
1. Tap "Wi-Fi" in the Settings menu and make sure the slider Wi-Fi is set to "On."
2. Waiting for a pop-up window appears with a list of available networks. Tap the name of the network you want to participate.
3. Enter the password for the network. If no password is required, the iPod will not ask for one.
4. Select "Cancel" if you have a closed network that is not in the list to close. Tap "Other" closed and the network name and password type of security. Use this option if you have access to a Wi-Fi network is closed not featured in "available networks."
5. Check the left corner of the screen. When connected to Wi-Fi indicator lights. The iPod touch will automatically detect and connect to that network when the signal range.
Computers & Internet Logo
ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
233 people viewed this tip
David Payne
David Payne
