Tip & How-To about Computers & Internet
How to install SSH on my iPod Touch
If you're used to using SSH or Secure Shell applications on your computer to protect connections to remote hosts to determine, you may want to use SSH with your iPod Touch, Apple's portable multimedia player with a touch-sensitive display. The iPod Touch connects to the Internet via Wi-Fi, so you can connect to Apple's App Store to look for an SSH application and download it directly to the device. After starting the SSH application, use it to connect to a remote host via the Internet when in range of a WiFi hotspot
1. Press the "Home" button of your iPod Touch.
2. Touch the "App Store" icon for Apple's App Store on the Internet via Wi-Fi access.
3. Tap "Find" and type a keyword such as "SSH" or "Terminal" in the search bar and tap "Search". The list of applications appears.
4. Tap the name of an application to see pictures and read about how it works.
5. Tap the word "Free" price or beside the application name from the list, tap "Install". Enter your Apple ID at the prompt. SSH application downloads and installs on the home screen of your iPod Touch.
6. Press the "Home" to return to the home screen. SSH tap the application icon to start it.
Computers & Internet Logo
Suggest me the most secure web hosting service?
When it comes to web hosting I will trust only those services that can assure security. Being secure is very important for any Internet user and I always wanted a secure web hosting service provider. For ensuring a secure web hosting service I went on to use the Hosting Australia services and they are using the latest version of cPanel, CloudLinux & KernalCare means and I believe this helps to patch the latest vulnerabilities & security threats. They also helped in employing daily antivirus scans.They were worthy of using and also handled all data with security. I am happy with their services and also would recommend it to all of them who are planning for a secure web hosting service!.
Dec 05, 2017 | The Computers & Internet
my icons arent showing up after i ssh
Assuming that you are using the term "SSH" correctly:
SSH is a protocol used to remotely access the command line for a remote machine, usually linux.
SSH provides no direct way to share a desktop or any other graphical interface.
However, with a lot of configuration, it may be possible to use it to form a secure link by which you can open a VNC connection, which does share the graphical environment.
Mar 14, 2011 | Computers & Internet
remote desktop
Here is a short list of applications that can be used.
1) VNC (Virtual Network Computing) is a remote display system which allows the user to view the desktop of a remote machine anywhere on the internet. It can also be directed through SSH for security.
Basically you install VNC server on the server and install client on your local PC. Setup is extremely easy and server is very stable. On client side, you can set the resolution and connect to IP of VNC server. It can be a bit slow compared to Windows remote desktop and also has the tendency to take more time refreshing over low-bandwidth links. All in all VNC is an amazing piece of free software that gets the job done.
There is RealVNC , TightVNC and UltraVNC. Each has it’s advantages and disadvantages. Most popular one is RealVNC but if you’re upto it, experiment with all three and choose the one that works for you best. By default, communication between client and server is in clear text on port 5900. However, you can easily route all traffic via SSH tunnel. Here is a quick way of setting it up if you have access to command line shell:
ssh -ND 5900 <user>@remote.server.com
When you get prompted, enter your password. Pop open VNC client and connect to ‘localhost’. This’ll route your connection to VNC server on remote machine.
You can download VNC from:
  1. http://www.realvnc.com/download.html
  2. http://www.tightvnc.com/download.html
  3. http://www.uvnc.com/
2) Then there is FreeNX. FreeNX is a system that allows you to access your desktop from another machine over the internet. You can use this to login graphically to your desktop from a remote location. One example of its use would be to have a FreeNX server set up on your home computer, and graphically logging in to the home computer from your work computer, using a FreeNX client. It provides near local speed application responsiveness over high latency, low bandwidth links.
FreeNX can be configured to run via SSH without any tunneling. It binds to your existing SSH install. Instead of guiding you through the installation of FreeNX in this article, you can visit the following URLs that’ll guide you through the installation on Ubuntu:
  1. https://help.ubuntu.com/community/FreeNX
  2. http://ubuntuforums.org/showthread.php?t=97277&highlight=freenx
  3. http://freenx.berlios.de/ (FreeNX homepage)
3) The third free application is 2X Terminal Server for Linux. 2X TerminalServer for Linux is an Open Source project, licensed under the GPL and is free of charge. As far as performance goes, NoMachine’s technology is on par with Windows’ own Remote Desktop Protocol (RDP) suite, better than VNC. Both X2 and FreeNX is based on NoMachine technology.
Here are some quick links if you’re interested in using this software:
  1. Download at http://www.2x.com/terminalserver/download.htm
  2. Forum is at http://www.2x.com/forums
4) The last but not least at all is XDMCP. The X Display Manager Control Protocol uses UDP port 177. Compared to the list above, it’s not as easy to setup for remote desktop but it’s the original way of doing this on Linux. You can get setup instructions and other tips in the following URL:
  1. http://www.tldp.org/HOWTO/XDMCP-HOWTO/intro.html
In conclusion, there are many commercial products that are available as well. But this article is only based on open source products that can be freely used with no strings attached.
Jun 05, 2008 | Socket Communications Computers & Internet
300 people viewed this tip
David Payne
David Payne
