Tip & How-To about Cell Phones
LG ENV as a touch connecting to an additional input
You can use the 3.5 mm headphone jack on the Touch LG ENV to an audio device via an auxiliary input. If the audio cable is connected, the phone automatically updates all sounds cable. Then you can play music from the music player devices, such as car radios and systems external speaker. The 3.5 mm audio jack is a stereo connection, and is the audio standard for many electronic devices.
1. Connect one end of the audio cable to the 3.5 mm headphone jack on the Touch LG ENV.
2. Connect the other end of the cable into the auxiliary input device you are connecting.
3. Change the input of your audio device to take extra. Car radio, press the AUX button. See the device manual for specific instructions.
Cell Phones Logo
Audio on aux device
Connect a 3.5 mm (1/8 in) cable
from the auxiliary device to the
auxiliary input jack. When a
device is connected, the system
automatically begins playing audio
from the device over the vehicle spekers.
Mar 11, 2016 | 2012 Buick LaCrosse
how do i put my pioneer receiver to my cable tv,dvd. vsx-917-v-k
For this purpose I am using headphone output of the TV set. I connect the headphone output to the AUXiliary input of the receiver. All you need is an interconnection cable, one end with 3,5 mm stereo male earphone jack, the other end with a pair of RCA jacks. This output of TV provides an additional output signal to your receiver but volume control behaviour (independent volume control for earphone output etc.) changes for different brands of TV sets.
Jan 04, 2015 | Pioneer Audio Players & Recorders
want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
i have a samsung NC10. I have connected to my TV via the PC cable. I can see the screen but here no sounds. I have connected the red/yellow/white audio cable to the tv. It has a jack plug on the other end. do i insert this into my headphone socket at the netbook end. there is no other single jack plug like audio in on the tv other than the usual three plug connection..please help confused and exasberated now!!
The cable you are using is a rca audio/video cable. The colors translate to:
  • red=audio,right
  • white=audio,left
  • yellow=composite video
Your laptop headphone input uses a ⅛′ (3.5 mm) mono and stereo (TRS).
You need a Stereo 3.5mm mini phone plug male to 2 RCA female connectors.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Nov 07, 2009 | Samsung NC10-11PBK Netbook
254 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
