20 Most Recent The Times Case Corporation Tractors International Harvestor Questions & Answers
Well I asked around and found about 0.020 or in better terms of understanding is about 20 thousand's of a inch.
The Times Case... | Answered on May 17, 2019
You will have to get the degree of timeing from a manual. But on the outside of the pump is a plate with 2 screws the plate is about 1/2" x 1-1/4" take it of and you will 2 disks the one to the back should have a black line and it does not turn the front one does turn so you may not see it at first. If not turn the engine over til toy see the front come into the opening when it goes into the opening you are coming up to #1 compression go to the belt pulley on front of engine and set degree of time to the pointer then check the 2 lines on the pump they should line up if not loosen the 2 nuts that hold the pump on and rotate to line up lines in pump if in line that is it. Shut fuel of first because it will run out. That is about it.
http://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=farmall&th=454456
The Times Case... | Answered on Dec 03, 2017
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
The Times Case... | Answered on Oct 02, 2014
change filters, and clean the inside of pipes from tank to injectors, use a thin peice of wire to do this
The Times Case... | Answered on Jul 13, 2014
See if there is enough hydraulic oil in the system,check the level,this is probably cause there is not enough oil.
The Times Case... | Answered on Jun 21, 2014
I had a close to that problem and decided the fuel was the problem,So I added a electric fuel pump between the fuel tank and the manual fuel pump,,but also check the fuel line between the fuel pump and the fuel tank,for it may plugged with dirt or the manual fuel maybe to weak to the job ,so I added electric fuel and the no more problem with air locks or no fuel to keep the tractor running.
The Times Case... | Answered on Jun 05, 2014
The Times Case Corporation Tractors International Harvestor Logo
113 questions posted
Top The Times Toys Experts
Bill Boyd
Bryce Wendland
Bryce Wendland
Level 1 Expert
Brandon...
Brandon...
Are you a The Times Toy Expert? Answer questions, earn points and help others
View Most Popular
The Times Toys
  • The Times Toys
Most Popular Question
diesel tractor ran out fuel now start
  • Toys
