20 Most Recent
Westinghouse 24 in. MDB121 RF Built-in Dishwasher Questions & Answers
Glasses /cups/dishes on the top
If you have hard water glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1/4 of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
How to fix h19 code popped upon Westinghouse dishwasher, please?
H19 is an error code indicating that the water draining has reached a certain threshold and has not been cleared properly. To fix this issue, you'll need to check the drain hose and ensure it is connected properly and not clogged. You should also check the drain pump to make sure that it is operating correctly and that it is not blocked. If these steps do not resolve the issue, it may be necessary to call a technician for further assistance.
Westinghouse dishwasher F5 error
google westinghouse dishwasher wsf6608x error codes f5
F5 signals an error in the water supply line, which may mean that the tap is not open far enough or that there is an error in water pressure
Westinghouse Dishwasher F5 Error - Water Level Fault
Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Westinghouse SB907 Dishwasher
ON the the control pannel it might show a symbol of a lock. You will need to hold that key or sometime Keys for 3 to 5 seconds to release the control lock.
