20 Most Recent Krell KAV-300i 2-Channel Amplifier Questions & Answers
Parts included with new amp in box
You should be able to figur that out but first read the instructions they contain some amazing information. I can not help you because I have no idea of what you are asking.
11/27/2014 4:28:22 PM • Krell KAV-300i... • Answered on Nov 27, 2014
Why is it that only my xlr and tape inputs working, no signals from s1, s2, and s3,. thanks in advance
If you're able to switch between them then your issue is possibly relay, relay driver or microprocessor related; all of which require a service techs attention. hope this helps. Gene
6/16/2014 11:58:59 PM • Krell KAV-300i... • Answered on Jun 16, 2014
0answers
0answers
0answers
0answers
Hi, I have to replace
Onsemi ( which is motorola) is a good pic for replacements If youre looking at the 21195 , then there must be a compliment to that as well? 21194 or 21196
10/10/2010 2:18:47 PM • Krell KAV-300i... • Answered on Oct 10, 2010
Hello If i wanted to refresh my Krell KAV-300i
Can you please provide more information about what you mean by "refresh"? Is there a performance problem or funcitonal problem with the unit?
Thanks,
Dan
8/17/2010 8:00:08 PM • Krell KAV-300i... • Answered on Aug 17, 2010
Not enough bass response, how do I increase the bass?
Check the Krell website
4/17/2010 1:27:40 PM • Krell KAV-300i... • Answered on Apr 17, 2010
Hello, after plugging on Ipod through my preamp
Sounds like the volume was way up when the iPod turned on. iPods are DC and cause a sudden thump through the speakers when they power on.
If the fuse is not blown, there may be another fuse you have not seen. Most amps have three to five fuses especially a 150watt/channel like the Krell.
4/17/2010 12:49:07 AM • Krell KAV-300i... • Answered on Apr 17, 2010
I think maybe the xlr input might be going bad
try switching cables from one channel to the other and see if the problem follows the cables.
4/12/2010 11:02:08 AM • Krell KAV-300i... • Answered on Apr 12, 2010
Fuse at power cord blows
first check your speaker cabels for short circuit and speaker for  short coil .after you confirm there is no shotr of cabel wires by checking with avometer in ohm postion.connect speaker if the problem excit your speaker is guilty - change it with same configuration.about switches put it in low order and chech for sound level and you can go up after that.
1/14/2009 1:51:25 PM • Krell KAV-300i... • Answered on Jan 14, 2009
2answers
Krell kav300i, increasing volume by itself.
That is an extremely odd problem. I suggest finding a tech in your area who is familiar with the unit, or contacting krell directly.
10/22/2008 10:21:07 PM • Krell KAV-300i... • Answered on Oct 22, 2008
0answers
Krell 2250 was operating well .. Suddenly left channel stopped .. checked the fuses all ok .. Any idea. ?
try subbing out another newer speaker for the left one ? if sound returns then that older speaker is defective .
11/12/2016 2:09:57 AM • Krell Audio... • Answered on Nov 12, 2016
Where can I get a fuse for my Krell KSA 300 amplifier.I had a blown fuse on the left channel.
Fuses rarely go on their own. The cause is likely to be a shorted semiconductor device in the left channel output. Fuses are generally not specific to any brand. Is the fuse a tube with metal ends? If it is measure the length in MM. Then look at the end and you should see the rating. Either in A for Amps or MA for milliamps. Any electronic parts supplier should have the one you want in stock. Buy several, for if the part I mentioned has gone, it will blow again.
9/16/2016 11:33:57 PM • Krell Audio... • Answered on Sep 16, 2016
Where I get a blown fuse on the left channel of my Krell KSA 300 amplifier
http://www.manualslib.com/manual/90296/Krell-Industries-Ksa-100s.html?page=18#manual Look on page 18
9/10/2016 3:48:52 AM • Krell Audio... • Answered on Sep 10, 2016
How do I brigde a krell show case amp from 5 channels to three channels
Thai will require removal of the top cover to move jumpers or program dip switches in proper order. This will be explained in the owners manual which is located at Krells web site. Steven Leckrone The Service Department 30 Unquowa Hill St Bridgeport CT 06604 203-331-0671 [email protected] www.theservicedepartmentct.com
11/14/2014 11:54:12 AM • Krell Audio... • Answered on Nov 14, 2014
20 questions posted
Top Krell Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Krell Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Krell Audio Players & Recorders
Most Popular Question
not enough bass response increase bass
  • Audio Players & Recorders
