20 Most Recent Lionel The Polar Express Train Set Questions & Answers
indicates a dead short to ground in the smoke unit that is overloading the transformer
replace/repair the smoke unit
Lionel The Polar... | Answered on Oct 30, 2017
You've done the right thing by talking with Lionel. Their techs should be able to guide you trough trouble shooting as it seems that you have some knowledge of electronics.
Lionel The Polar... | Answered on Apr 26, 2017
electric trains that sit for a few years require cleaning (yeah I know how'd it get dirty in the box ) but its not the same kind of dirt u/I see its a type of oxidation called corrosion , and it affects the metal parts of set , IE: tracks , wire connectors, engine power pick-ups on bottom of engine they ALL get this light powdery stuff on them this "stuff" will not pass power over to engine and it will not run , this powder can be easy removed with a light rub of 3M scotchbright pad , I don't recommend using steel wool , but I have in a pinch before and 4 sure don't use brillo as this has soap in it (worse than powder)
Lionel The Polar... | Answered on Feb 23, 2016
Lionel uses insulated wheels on there power pickup trucks , one side will have insulation bands and one will not , insulated bands need to be all same side on same truck , lead end is different than tail end this is how it picks up power from tracks , sometimes trucks axles get popped out in playing and maybe don't get popped back in the same way , also its possible for insulating bands to get holes in them from use , a dot or two of black latex paint fixes these up (don't paint entire wheel)
Lionel The Polar... | Answered on Feb 17, 2016
I have used 18ga lamp wire but you can use wire as thin as telephone wire. My rule of thumb is to use thicker wire (lower gauge number) the more motors on the train you are running. 20 or 22ga is generally used by most.
Lionel The Polar... | Answered on Oct 19, 2015
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Lionel The Polar... | Answered on Feb 10, 2015
I am assuming that the throttle is off when you put the train on the track. If off, then you are correct that there is an internal short in the engine. You might try disassembling the unit and looking for a pinched wire specifically from a roller(s) (center rail pickup). You might also check for a short between a pickup roller and a wheel with a VOM. Make sure the wheel is not the one with the neoprene belt.
Lionel The Polar... | Answered on Feb 03, 2015
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating hours wondering why their train wouldn't move.
Lionel The Polar... | Answered on Dec 25, 2014
You will have to solder them using a pencil soldering iron.
Lionel The Polar... | Answered on Dec 17, 2014
CLEAN wheels, roller pickups & track.
Lionel The Polar... | Answered on Oct 15, 2014
My son just got this train and we are having the same problem. Taking the last car off solved the problem for us. I think it has something to do with accessories and the transformer voltage output (See page 14 and 15 of the instructions).
I have still not determined why it won't run with the final car but am assuming it has something to do with the lights on the cars pulling too many amps and not enough left to run the train. I will let you know if I find a solution. If anyone else knows how to solve the issue, any assistance would be greatly appreciated.
Thanks
Lionel The Polar... | Answered on Jun 16, 2014
Remove the shell. Soak up as much as you can. Leave out to dry or use a hair dryer on low until controls are dry.
There are more than just one Polar Express set. What's the set number?
Lionel The Polar... | Answered on May 06, 2014
Lionel The Polar Express Train Set Logo
80 questions posted
Top Lionel Crafts & Hobbies Experts
ray gallant
Tom Chichester
Bill Boyd
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
View Most Popular
  • Lionel Crafts & Hobbies
Most Popular Question
lionel train run all
  • Crafts & Hobbies
