20 Most Recent Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft. Counter Depth Side-by-Side Questions & Answers
E68 on frigidaire dryer
Good Morning Randy, this is Z. Thank you for your post! Typically error code E68 on your Frigidaire dryer can indicate one or two issues. First problem could be that one of the keys (buttons) is stuck closed (active). Enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again. If button is free but the error code still exists, the electronic control will possibly need replacing. Second issue could possibly be a current leakage to ground on heater or fuse opened. However, I would strongly suggest contacting a professional to the check the resistance of the heating element (should be approximately 14ohms) or the resistance between the ground and both heater terminals. It should be open when heater terminals are disconnected. If the readings are incorrect, then you may have a faulty heating element. Best regards!
4/3/2014 1:44:45 PM • Frigidaire... • Answered on Apr 03, 2014
Electrolux PHSC39EESS5 refrigerator: EF code, but
Hi,When this happens your fans is getting the incorrect information on how to run, on some occasions both the fan and control to the fridge had to be replaced at the same time. Disconnect the evaporator fan motor and run the unit as normal. If the computer allows the compressor to run at least five mins, just replace the fan motor, if not replace both.Control board is under the unit Part# 241511102 (only if needed)Parts number for fan motor P#241509402 both of these parts should be available through your local part house or REPAIR CLINIC, to avoid shipping cost and any return issue you may have.I hope this helps, good luck I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
10/21/2013 4:31:31 PM • Frigidaire... • Answered on Oct 21, 2013
1st water dispenser not working now EF code
EF code on a Frigidaire refrigerator means Evaporator Fan problem. The motherboard on the FGHC2345LF can be sensing a problem with your evaporator fan. The fan could be failing so I advise that you keep an eye on the evaporator fan. All cooling will stop if this fan fails. I believe you are having two unrelated issues. The=> 241734302 Water Inlet Valve10_5_2012_2_58_41_pm.jpgis possibly becoming defective and not allowing water to dispense. 241509402 Evaporator Fan Motor10_5_2012_3_07_20_pm.jpgI will be here should you have questions, Thanks Sea Breeze
10/5/2012 3:14:47 PM • Frigidaire... • Answered on Oct 05, 2012
Frigidaire gallery series dishwasher bottom door seal keeps falling out
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
12/2/2023 7:59:45 PM • Frigidaire... • Answered on Dec 02, 2023
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on. Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer https://www.justanswer.com > Appliance Repair Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ... 1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros https://forum.appliancepartspros.com > posts > t55646... Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video https://www.appliancevideo.com > question > refrigera... Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk https://hvac-talk.com > vbb > threads > 53155-Frigidai... Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ... Domestic Refrigerator Short-Cycling Dec 4, 2020 Wiring time delay for a short cycling compressor Jun 23, 2022 Walk-in short cycles Mar 7, 2021 Walk-in compressor short cycling Oct 20, 2008 More results from hvac-talk.com
11/26/2023 9:05:58 PM • Frigidaire... • Answered on Nov 26, 2023
2answers
I have a code 56 on the panel of my Frigidaire side by side refrigerator. I unplugged the unit and plugged back in but the code is still there. None of the buttons work on the panel.
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with Check and scroll down this website to get the description way down on the webpage: https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
10/23/2023 3:50:36 PM • Frigidaire... • Answered on Oct 23, 2023
Frigidaire Countertop Ice Maker EFIC117-SS Won't Turn On
Check out the videos and also try the button hold reset.
Frigidaire Countertop Ice Maker Troubleshooting
icemakerbasics.com https://icemakerbasics.com > Troubleshooting Jun 26, 2023 - Hold/press the power button for 10 seconds · Unplug your Frigidaire ice maker. · If there's water in the reservoir, drain the water reservoir. https://www.google.com/search?q=Frigidaire+Countertop+Ice+Maker+EFIC117-SS+Won%27t+Turn+On ..
10/8/2023 8:12:42 PM • Frigidaire... • Answered on Oct 08, 2023
Frigidaire EFIC123-B-SSRED Counter Top Ice Maker parts diagram please?
No parts diagram available. It is made in China and is classed as a disposable item. https://www.google.com/search?q=Frigidaire+EFIC123-B-SSRED+parts+diagram You can try here, but a new one is less that $100.
Shop Ice Machine Replacement Parts Online
Frigidaire Appliance Parts https://www.frigidaireapplianceparts.com > Ice-Machi... Shop for Parts. With fast shipping, it's no wonder people trust Frigidaire Appliance Parts. For best results, please enter your model number. ..
8/23/2023 9:31:36 PM • Frigidaire... • Answered on Aug 23, 2023
I have an old Frigidaire freezer elite. Does the max. setting lower the temperature and the min. setting raise the temperature or the other way round?
minimum= lowest. maximum = highest. So to lower temp turn knob to minimum
8/9/2023 1:44:59 PM • Frigidaire... • Answered on Aug 09, 2023
Frigidaire refrigerator stuck on Sabbath Mode
Depends on model. Generic advice in the link and videos. You can effect a power reset by pulling that wall plug for 30 minutes. Sabbath Mode is turned ON and OFF by pressing and holding both the freezer "? Down" and refrigerator "? Up" indicators for five (5) seconds. The display shows "Sb" while in Sabbath mode https://www.google.com/search?q=how+to+turn+off+sabbath+mode+on+frigidaire+refrigerator ..
7/14/2023 2:41:24 AM • Frigidaire... • Answered on Jul 14, 2023
2answers
The temperature of the freezer portion of my Frigidaire Gallery refrigerator is varying for no apparent reason. What are the likely causes and fixes?
check door seal or not closing correctly ---fan failure -stat /control board glitching
7/6/2023 7:48:42 PM • Frigidaire... • Answered on Jul 06, 2023
What does E6 code in Frigidaire wine fridge mean? Model FGWC5233TS
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction. To troubleshoot and resolve the E6 error code, you can try the following steps:
  1. Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
  2. Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
  3. Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
  4. If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
6/29/2023 6:36:22 AM • Frigidaire... • Answered on Jun 29, 2023
Frigidaire Gallery FGSC2335TF9 is randomly tripping the circuit breaker or breaker is tripping and shutting down the fridge.
limited information ---unable to give an answer --since you need to test the unit most likely problems overheated/failing compressor [dirty/restricted air flow condenser area --condenser-evap fan fail /short--circuit short ---------breaker failing [but if tripping and resets normal usually not the case ]
6/13/2023 1:11:40 PM • Frigidaire... • Answered on Jun 13, 2023
Frigidaire Side by Side Refrigerator. How to stop the loud humming noise coming from it please?
Question edited for clarity. It sounds like the compressor is struggling / overheating / failing. When was the last time your stripped the back out and removed all the fluff and debris? It overworks the compressor and gets red hot when the condenser coils get blocked. The struggling compressor causes the humming. Turn it off, keep the doors closed and vacuum it all out. Clean underneath and you might as well clean the floor and walls around it as the plan is to leave it disconnected for 1 to 2 hours to cool down and settle the refrigerant gas/liquid. Some other ideas below. The evaporator fan motor circulates air over the coils to help keep things cool inside your fridge. If this motor starts to go bad, it will make a buzzing sound as it struggles to circulate air. You'll need to replace the evaporator fan motor to fix this problem. Aug 22, 2022
Frigidaire Refrigerator Runs Loud? This May Be Why...
5/26/2023 4:50:51 PM • Frigidaire... • Answered on May 26, 2023
What are the physical dimensions of Frigidaire FRT18SJGW2.
Does ir look the same as this FRT18? https://www.ajmadison.com/cgi-bin/ajmadison/FRT18G6JW.html Refrigerator Capacity: 14.13 Cu. Ft. Freezer Capacity: 4.07 Cu. Ft. Total Capacity: 18.2 Cu. Ft. Width: 29 5/8 Inch Depth: 33 5/8 Inch Depth with Door at 90°: 59 7/8 Inch Height: 66 1/8 Inch No. of Shelves: 2 Gallon Door Storage: Yes Water Dispenser: No
5/3/2023 11:29:17 PM • Frigidaire... • Answered on May 03, 2023
Frigidaire FGHC2345LF Gallery 22.6 Cu. Ft. Counter Depth Side-by-Side Logo
Popular Tags
3 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
e68 frigidaire dryer
  • Refrigerators
