20 Most Recent
Renault Dauphinoise PTT French Post/Telephone Van Questions & Answers
FITTING A OIL FILTER FOR A RENAULT KANGOO
If its a kangoo 1.6 the oil filter is between the engine and the radiator at the front of the engine on the left hand side (from the front of the car) and is acessable from below.
3/26/2015 12:17:30 PM •
Renault...
Answered
on Mar 26, 2015
What tool do i need to change oil in my kangoo
Ok this is a late post I knoe only just bought a kangoo 1.5 dci, I like to think I have good tool kit sees me through just about any job, except this one, undoing an oil drain plug.....AW man what a pain ...............something.Two britool tool kits and no joy. I swear I think the french are paying us back for donald rumsfeld's cheese eating surrender monkey jibe....I mean why not just a bolt nice and easy...so the engine flush is in the oil, I am far from a parts company, no driving the car now then..So its the old case of nessescity being the mother of all invention. I like most of you searched goolgle in hope of an answer and nothing..Until I remembered an old door lock I had on the top shelf and after hours of getting nowhere, it turns out that the spindle that goes between the handles of a door was pure goldielocks(UK anywayFrench probably got there own sizes) Its worth mentioning I did need to soak the sump drain plg with Wd40 qite afew times. PS the door spindles is 8mm2If you dont have the proper tool I hope yo see this before you startAW
7/10/2012 5:14:02 PM •
Renault...
Answered
on Jul 10, 2012
THE FLASHING LIGHT ON THE DASH BOARD WILL NOT STAY
the key is at fault, on mine the push bit is missing on key and when dirt or dust get in it the light flashes to resolve i simply blow off dust or wipe off put key back in and it works every time it took me months to figure that out good lukk
9/25/2010 6:42:05 AM •
Renault...
Answered
on Sep 25, 2010
Need tool for changing oil on renault kangoo
you req a sump plug tool for this job basically its a square plug you can by these tools in motoring shops or on ebay don't cost that much if your in uk you can buy them in halfords.
2/13/2010 4:04:15 PM •
Renault...
Answered
on Feb 13, 2010
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
Can I fix an error on my orthofix 2212 it shows
Why are you guys giving answers to fix a printer when the OP is asking how to clear the error code on an orthofix bone growth stimulator used to help the bones fuse together after back surgery... I'll give my best guess as I am having the same issue. They are set to last a certain amount of time and designed to stop working after that set time. In my case I got the device, postponed my surgery and my orthofix wouldn't work after I actually had the surgery.. 2nd best guess would be a battery issue because I can charge mine fully, turn it on for about 10 min, put ot back on the charger and it flashes all 4 bars like its completely dead.. but there is a number you can call that can help you more than I can, 18005354492
1/17/2024 9:11:13 PM •
Toys
Answered
on Jan 17, 2024
How ca i overcome my
Tried and tested solutions.
Go out and take deep breath and in your mind say 'I want to get rid of this bad habit"
1/4/2024 6:43:12 PM •
Toys
Answered
on Jan 04, 2024
