20 Most Recent
Capresso 455 CoffeeTEAM Therm Stainless Coffeemaker - REFURBISHED Questions & Answers
I want to descale my capresso 455 with white vinegar, and need instructions
Super easy and have done it for years. When water reservoir is empty fill with a small amount of white vinegar. Then add water until full. Wipe out other parts of machine. You won't want any grounds to hang around. Do not add grounds, but replace basket empty. Allow machine to cycle as if you were making coffee until reservoir is empty. Repeat process with clean water to flush out any leftover vinegar taste. You may have to do it two or three times until the smell is gone. Using distilled water in your machine will keep deposits from forming.
De'Longhi PrimaDonna Soul Coffee Maker not making milk foam.
The milk delivery tube is very narrow bore and in my experience you will find the tube is blocked with congealed milk solids even if you clean then regularly. You need an enzyme milk cleaner like Rinza and even with that you need to manually massage the tubes or remove the blockages. The service engineers just replace them.
What does a CIMBALI M34 CODES ERROR 053 mean?
That .depends on software and configuration. It is not a universal code You might find help in the manual.
CIMBALI M34 SELECTRON USE AND INSTALLATION Pdf Download ' ManualsLib
Inspect Electrical Supply: Ensure that the machine is receiving proper electrical power. Sometimes, an interruption in the power supply can trigger error codes.
Clean Components: Check if any components related to coffee grounds or filters are dirty or clogged. Clean the underpan gasket, filter holes, and filter holder outlet hole.
Coffee Ground Quality: Verify that the coffee grounds are of the correct consistency. If they are too coarse or too old, it can affect the machine's operation.
Discharge System: Examine the discharge system for any blockages.
