20 Most Recent Sony Xperia tipo dual ST21i2 Smartphone - Unlocked | Current Questions & Answers
SONY XPERIA ST21I2 ADB DRIVER
Install The flashtools drivers:Flashtool drivers exe Google Drive After install plug phone in to PC(make sure USB Debugging is enabled on the phone) if driver does not install itself go to Control Panel --> System --> Device Manager and look under Other devices there will be one named Sony Xperia(will have a yellow Question mark next to it) right click choose "update driver". Choose "browse my computer for drivers" on next screen choose "Let me pick" option. under manufacturer choose Sony Ericsson and then install the ADB driver(If the Sony driver does not work try installing the google ADB driver that can be found in the Android SDK)
5/21/2018 4:50:10 AM • Sony Xperia tipo... • Answered on May 21, 2018
0answers
Sony Experia Z3V won't connect to internet after SIM for straight talk was installed and setup
Your SIM Card will only work on the phone it was supplied with as it is linked to the IMEI number of the phone. If it doesn't, contact the telco. ..
2/3/2024 11:14:37 PM • Sony Cell Phones • Answered on Feb 03, 2024
2answers
How can I fix "unfortunately UI has stopped working" for a Sony Xperia phone?
system ui crashed and wont turn on - Sony - Comunidad
Sony https://community.sony.es > m-series > td-p ... Xperia Companion. This will do a clean installation of the latest ... August 2017. August 2017. Keep getting " unfortunately UI has stopped working" message. ..
1/30/2024 1:22:35 AM • Sony Cell Phones • Answered on Jan 30, 2024
Please I don't know how to set the sync for my Sony Ericsson. Please I need your help....?
Question edited for clarity and make real words. Settings > Accounts. Accounts, tap the name of the account that you want to synchronize with. A list of items appears showing what can be synchronized with the account. Tap the items that you want to synchronize.
Sony Xperia Z2 - - Synchronizing data on your device
xphonehelp.com https://sony-xperia-z2.xphonehelp.com > basic-settings
Sync your phone Sony Ericsson C902
Memotoo https://www.memotoo.com > how-to-sync-your-phone... Sync your phone Sony Ericsson C902 · 1 Open the sync app by browsing the following menus: Organizer » Synchronization · 2 Select New account · 3 Configure it with ...
Please gave me setup instruction how to setup SonyEricsson Sync ...
Sony https://community.sony.ee > xperia-archive > td-p Select Sony Ericsson. To set up Sony Ericsson sync in your phone: 1. From the Home screen, tap the applications bar 2. Tap Sony Ericsson Sync > Get started 3 ...
1/30/2024 12:49:33 AM • Sony Cell Phones • Answered on Jan 30, 2024
2answers
Sony Z4 Tablet. Can I send a text with it or do I have to have a mobile number?
To send sms you need to have a mobile number or you can use an online website like: https://www.atompark.com/bulk-sms-service/prices/
1/30/2024 12:27:29 AM • Sony Cell Phones • Answered on Jan 30, 2024
2answers
Sony Hbd tz510 remote code
The remote control code for Sony HBD-TZ510 home theater system may vary depending on the brand of the remote you are using. Here are a few common remote control codes that may work:
  • 30158
  • 31759
  • 31939
  • 31758
To program your remote, follow these steps:
  1. Turn on your Sony HBD-TZ510 home theater system.
  2. Press and hold the "Code Search" button on your remote control until the indicator light illuminates.
  3. Press the "DVD" or "AUX" button on your remote to select the device you want to program.
  4. Enter the four-digit code using the number buttons on your remote.
  5. Press the "Power" button to test if the code is correct. The device should turn off if the code is correct.
  6. If the device turns off, press the "Enter" button to save the code. The indicator light will turn off.
  7. If the device does not turn off, repeat steps 4-6 with a different code until you find the correct one.
Note: If you do not have the original remote control that came with your Sony HBD-TZ510, you may need to purchase a universal remote control that is compatible with your device.
2/24/2023 5:10:32 PM • Sony Cell Phones • Answered on Feb 24, 2023
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV. To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
2/13/2023 12:32:04 AM • Sony Cell Phones • Answered on Feb 13, 2023
How do I charge my Sony PSP 3000 with the USB cable when it's dead
Unless you have enabled the actual USB charge settings on the PSP you probably won't be able to charge it via a USB cable. The simplest solution here is to buy a replacement mains charger. They are usually reasonably cheap to buy for a decent quality one. I personally would avoid the really cheap ones as they are not always as good a quality as an original Sony charger. Another option is to buy a Docking Station for the PSP. Some of these are a table top stand that plugs into the mains electric supply. You then sit the PSP into it, attach a short power wire from the stand and leave it to charge as normal. There are other versions where you have to remove the battery from the PSP to charge it. The batteries are actually quite easy to remove and replace so you could consider buying a spare battery as well as a backup.
12/18/2022 7:29:30 PM • Sony Cell Phones • Answered on Dec 18, 2022
2answers
I cannot find out how to take the caller id off of my Sony tv with this remote. Is there anyone that can help?
I wouldn't have thought a television accepted phone calls. A model number would have solved for sure. 'make model manual'. Two conflicting answers. First one 'yes and how to', and the second 'Sony Bravia doesn't have Caller ID'. the MENU button on your remote, selecting the Settings tile, scrolling down, and then selecting Caller ID Settings.Mar 1, 2015
Viewing a thread - Sony Bravia...smart tv & telephone caller i.d.?
https://talk.newagtalk.com > forums > thread-view > Displ...
Caller ID - Sony Community
https://us.community.sony.com > question > caller-id Dec 26, 2015 - SONY Bravia TVs doesn't have Caller ID features.
4/17/2022 11:30:28 PM • Sony Cell Phones • Answered on Apr 17, 2022
I need a charge cable for sony experia tablet Model SGPT 1311
I need cable carger sony xperia model sgpt1311
12/13/2021 6:19:28 PM • Sony Cell Phones • Answered on Dec 13, 2021
I have a Sony KLV 32t550a. How to connect Android phone USB cable?
There should be more than a single type A USB header on the back of your TV.
12/13/2021 6:19:23 PM • Sony Cell Phones • Answered on Dec 13, 2021
2answers
Operator manual for Sony model HCDGR7 sound
Hi, you can find user manual in the following link:
12/14/2020 11:16:06 AM • Sony Cell Phones • Answered on Dec 14, 2020
How can I connect phone to TV?
You will need a MHL adapter to connect your cell phone to a TV.
12/7/2020 5:46:26 PM • Sony Cell Phones • Answered on Dec 07, 2020
My Sony km7 keep saying USB fail
YOU NEED TO FOREMAT YOUR USB CARD
8/31/2020 1:23:34 PM • Sony Cell Phones • Answered on Aug 31, 2020
4answers
Transfer photos from Sony xperia to virgin tablet
To transfer photos from Sony Xperia phone to tablet, it is possible, youjust need to plug your two devices with computer, and then open a mobile transfer software, it can help you transfer files like photos from one phone to other phone. Phone Transfer How to Transfer Photos from Android to Android
1/7/2020 3:33:39 AM • Sony Cell Phones • Answered on Jan 07, 2020
Good day Sir, please how do I connect my Mobile phone to Sony DHC-NXM2D.
I don't think this you could connect your phone to this particular component model.
10/16/2019 2:38:06 AM • Sony Cell Phones • Answered on Oct 16, 2019
How can i reset my sony experia x1
You should backup your data before resetting your phone. You may reset your Xperia X1 this way:
  1. Turn off the phone.
  2. Hold down Left and Right soft buttons.
  3. Hold down both Soft buttons press Power button for a few seconds.
  4. Release the Power button and keep pressing both Soft keys. Then release Soft keys.
10/16/2019 2:32:23 AM • Sony Cell Phones • Answered on Oct 16, 2019
Sony Xperia tipo dual ST21i2 Smartphone - Unlocked | Current Logo
10 questions posted
Top Sony Cell Phones Experts
Aron
ADMIN Eric
ADMIN Eric
NOEL
NOEL
Are you a Sony Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sony Cell Phones
  • Sony Cell Phones
Most Popular Question
sony xperia st21i2 adb driver
  • Cell Phones
