20 Most Recent
2008 Keeway Matrix 150 Questions & Answers
The Keeway Flash I have has not been started for a
Hi.
Keeway scooters usually do not have kickstand switch. Check if there is
one just in case. If there is kickstand switch bypass it.
Check fuel switch, fuel filter and hose.
Try starting with no fuel cap.
Check and replace spark plug.
Check carburetor oil and oil tube.
Check carburetor mixture and idle settings.
The carburetor needle may be clogged in some case the carb must be
disassembled to clean part or regulate needle height. Unscrew the
discharging fuel screw for the carburetor and check if there is fuel
flow. If fuel flows test the ignition wiring , CDI and coils in the
magneto.
I do not have the service manual for this scooter.
Here a service manual for a Keeway ARN 150, similar to Flash
Check the service manual tests and diagnostics are the same and wiring diagram is similar.
Regards.
Ginko
My 2009 keeway matrix 150
All you have to do is spray some starting fluid in the opening of the air box then try and crack it with the throttle wide open
New carb on 49cc scooter. only runs for 30 secs
Sound like the float in the carb is getting stuck the way to tell is loosen the screw at the very bottom or carb and see how much gas comes out it should run forever if only runs for a few secs the clean out carb
I have a Keeway Matrix
I had one on my bike. just disconnected the wires.. and it was fine.. it is under the seat.
2 stroke engine smokes. how do you adjust the fuel/oil mixture?
The thing with two strokes is that they smoke a bit under normal operation, and they smoke like mad if they haven't really been run for a period of time, I would advise you to run it for a while and see if that helps.
You should not need to adjust the mixture settings at all.
Hope this helps
Theres a cell phone light on the dash of the
Usually when you drive a bike it's very noisy and you feel vibrations through your body, this will prevent you from hearing a call ring or call vibration, that light on the scooter shows you when you get phone calls (is activated by the waves of the call you get on your cell phone).
Moped Faster
you could re-jet the carb or put a larger one on but that would mean making your own manifold, and you can open up the pipe to make it less restrictive.
