20 Most Recent 2008 Keeway Superlight 125 II Questions & Answers
2answers
Where is the fuse box for the headlight on a
under the seat, there is a little black box with a sleeve over it, the sleeve will have the spare fuse in it
3/3/2020 12:11:42 AM • 2008 Keeway... • Answered on Mar 03, 2020
On my keeway matrix, my
You may be looking at replacing the fuel cap - the old one is jammed and will probably have to be destroyed to remove it. I would use bolt cutters on the side and try to pry it off.
1/11/2018 5:18:32 AM • 2008 Keeway... • Answered on Jan 11, 2018
Tyre Pressures for Keeway Superlight 125 II
I also have a keeway super light 125 and the tire pressure is 33 PSI in the front and back.
6/16/2017 3:55:20 PM • 2008 Keeway... • Answered on Jun 16, 2017
What headlight bulb do i need for a Keeway 125?
You need a BA20D 35/35w 12v Go for the xenon, it's much brighter ?
1/26/2017 6:37:05 PM • 2008 Keeway... • Answered on Jan 26, 2017
4answers
Manual for a keeway speed 125
Look for manuals here:
http://keewaysuperlight.blogspot.com/
2/17/2014 8:58:31 PM • 2008 Keeway... • Answered on Feb 17, 2014
I have bought a keeway supershadow the button start wont work
sounds like youve got a bad connection on button or the wires from it down the bars to headlight area ! a multi metre would help find it !
12/15/2013 2:13:11 PM • 2008 Keeway... • Answered on Dec 15, 2013
2answers
2 broken side panels for keeway superlight 125
This is something you should contact a Keeway dealer for....good luck...Tim
9/11/2012 10:52:15 PM • 2008 Keeway... • Answered on Sep 11, 2012
2answers
2009 keeway dorado cruiser, where's
there are just two places that they put fuse boxes, one is under the seat, the other is under a side cover, just look u will easily find it.
9/6/2012 6:07:31 PM • 2008 Keeway... • Answered on Sep 06, 2012
Were is the front brake switch on a keeway superlight
It is part of the front brake master cylinder.
5/24/2012 9:34:26 PM • 2008 Keeway... • Answered on May 24, 2012
Keeway superlight 125cc....only getting 65mph
Hi,,,you can change the front sprocket to a bigger one(more teeth) or change the rear sprocket to one with less teeth.
the front is the cheapest option and changing one tooth on the front is equivelent to 3 on the rear.
9/9/2011 10:41:40 PM • 2008 Keeway... • Answered on Sep 09, 2011
Turn signels will not work
Check your fuses. Should be in the owners manual
6/12/2011 8:34:06 AM • 2008 Keeway... • Answered on Jun 12, 2011
Bike starts on stand the cuts out off the stand
had the same problem & took my f-act 50 back to dealer, he removed seat and adjusted the large brass idle screw on the carb; idled it up, small turn, reinstalled seat, haven't had anymore problems
5/14/2011 2:12:39 AM • 2008 Keeway... • Answered on May 14, 2011
Can i bypass the cdi on 2008 Keeway Superlight
Sorry, no. The CDI runs the lot.
3/6/2011 9:18:04 PM • 2008 Keeway... • Answered on Mar 06, 2011
Oil filter is the same as what other model
each bike has its own filter number that is unique to the engine.
9/29/2010 9:28:33 PM • 2008 Keeway... • Answered on Sep 29, 2010
Removing seat on Keeway 125
on the left side of the bike at the back there is where you can insert your key, put it in and turn, behind the key there is a lever pull it down and the seat will release, you need to pull up the seat at the same time.
good luck.
9/4/2010 7:57:11 PM • 2008 Keeway... • Answered on Sep 04, 2010
Were I can download keeway
this a the keeway website
http://www.keeway.me/models/superlight125/index.php
although recently the manual wont open i think it may be under maintance/update. but it is always worth going back to the website now then just to check.
best of luck.
9/4/2010 7:53:52 PM • 2008 Keeway... • Answered on Sep 04, 2010
How do I remove the battery cover. My battery is
hi, if yout battery is dead kickstart the bike until it starts and then go and ride it for about 45minutes to an hour, this will put a good amount of electric into the battery. If the bike will not start then pull out the battery and place it on a flat surface, there should be a low and a high level, if it is below the low line take it to a local mechanic and either they will order you a new battery or depending on the type of battery they will add more fluid into it for a small fee.
good luck.
9/4/2010 7:48:12 PM • 2008 Keeway... • Answered on Sep 04, 2010
Over revved then cut out
there is a possibility the valve timing has jumped a tooth or two.
a manual will help greatly, and explain it better than I can here in a few lines.
you will need to take the rocker cover off, and remove the small timing plug on the alternator cover, align the crank with its mark on TDC, check the valve clearances, if they both have clearance it is on top dead centre, if the valves are tight , rotate the engine one revolution.
The cam lobes will be pointing away from the lifters.
check the timing marks on the cam sprockets, there should be a small dot or arrow on each sprocket, align with the rocker gasket surfaces, if not it may have slipped. It may only be one tooth out as the bike still idles. This is general advise only, if you think it has slipped from these directions get the exact manual for the model and reset the timing to the book.
4/30/2010 1:13:46 PM • 2008 Keeway... • Answered on Apr 30, 2010
Oil leak on head
Try the shop it was bought from, if bought new they MUST supply spares to fit
Otherwise find out which Japanese engine it is a copy of & try a head gasket for that
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
1/29/2010 2:58:42 PM • 2008 Keeway... • Answered on Jan 29, 2010
2008 Keeway Superlight 125 II Logo
51 questions posted
Top Keeway Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Keeway Expert? Answer questions, earn points and help others
View Most Popular
Superlight 125 II Keeway
  • Superlight 125 II Keeway
Most Popular Question
bought keeway supershadow button start
  • Motorcycles
