20 Most Recent JUMP START SYSTEM Questions & Answers
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
JUMP START... | Answered on Jan 24, 2019
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals free
JUMP START... | Answered on Jan 22, 2019
I live in Brunswick Ga, can you tell me where to find a replacement ac charging plug and the cigarette lighter plug for my Vector Jump Start 450 amps,(VEC012c).Thank You Mr. Prior
JUMP START... | Answered on Oct 07, 2018
I cannot see the manufacturers name. If you get me the manufacturers name and the model number then I'll be able to find out where you can get the power cord.
JUMP START... | Answered on Jan 20, 2018
How old is the starter pack? The battery(ies) die after 3-5 years. FWIW I replaced an AGM-type battery in a starter pack and found out later it was almost as expensive as buying a new one from COSTCO or Uncle Sam's. Sounds like you're in Oz so COSTCO might not be available.
JUMP START... | Answered on Oct 22, 2017
Not to my knowledge, usually the charging fuse will be a low value in relation to the voltage output and the wattage. Maximum would be 10amps or so and the unit would charge all night to come up to charge.
JUMP START... | Answered on Sep 14, 2017
Contact Black and Decker at 1 (800) 231-9786
JUMP START... | Answered on Jan 08, 2017
https://www.savingology.com/ProductDetails.asp?ProductCode=Black-VEC012BD-VEC012C-AC-EGR&click=2&gclid=CJXoxsmemc0CFZA2aQodCwEGXw
JUMP START... | Answered on Jun 23, 2016
I suggest you keep trying to start for 3 or 4 ten second bursts with ten seconds between each. Dragging current through a poor connection will tend to cause heating of the connection. Immediately feel each battery connection and each connection along the battery leads to the starter motor not forgetting where the earth leads connect to the bodywork.
Using a voltmeter to measure the volt drop along the leads would be an easier way to check the leads and connections.
Pay particular attention to terminals that are crimped to the cables rather than being soldered. Sometimes there is a dirty connection inside the crimp where it can't be seen or cleaned and the only cure is to cut it off and replace it with a more conventional type of soldered terminal.
It might be a good idea to start with to test the new starter to ensure it is good....
JUMP START... | Answered on May 10, 2016
Battery could be bad. A bad battery can sometimes show a surface charge (voltage) on monitoring system, but when you go to use it nada happens because it has no current.
JUMP START... | Answered on Feb 15, 2016
Here's a link to the power charger I needed, its a Black & Decker Replacement A/C Charger. I ordered it at the following:
http://www.amazon.com/Black-Decker-5140045-42-Replacement-Charger/dp/B002V6VIZW/ref=sr_1_1?s=hi&ie=UTF8&qid=1445366598&sr=1-1&keywords=Black+%26+Decker+%235140045-42+Replacement+A%2FC+Charger
JUMP START... | Answered on Oct 20, 2015
You can but it will shorten the battery life.
JUMP START... | Answered on Jun 18, 2015
What kind of battery are you asking for? Get yourself a good battery charger and follow the directions found in the box. It will explain everything you need to do.
JUMP START... | Answered on Apr 10, 2015
For replacement parts (charging adapters, etc.), contact Technical Support, toll free
at (866) 584-5504. Here's the owners manuel. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Vector/VEC012POB.pdf
Good luck.
JUMP START... | Answered on Mar 29, 2015
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
JUMP START... | Answered on Mar 26, 2015
battery plus or e-bay better price
JUMP START... | Answered on Mar 16, 2015
JUMP START SYSTEM Logo
484 questions posted
Top Vector Vehicle Parts & Accessories Experts
Sheldon Dedek
Norman Al-Anbar
Are you a Vector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Vehicle Parts & Accessories
Most Popular Question
leave power pro autopower 300a
  • Vehicle Parts & Accessories
