20 Most Recent
Eliminator MotoMaster Mobile Power Inverter 175 W Questions & Answers
Ocp code
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiC9dTmy6ODAxUpmokEHW69CjgQFnoECA4QAw&url=https%3A%2F%2Fen.wikipedia.org%2Fwiki%2FOpen%25E2%2580%2593closed_principle%23%3A~%3Atext%3DIn%2520object%252Doriented%2520programming%252C%2520the%2Cwithout%2520modifying%2520its%2520source%2520code.&usg=AOvVaw1Jpi8fgKYUL30yZ5JXAjry&cshid=1703266989913712&opi=89978449
I need to replace the cigarette lighter plug on my
- One wire is the hot and the other wire is the ground.
To find which wire is the ground wire,Take a volt meter and set it on ohms,connect one of volt meters leads to case ground,take the other volt meters lead and touch it to one on the inverters wire,when the needle or digital read out advances or makes a buzzing sound, depending on the type of meter you use,that is the ground side. Black is usually ground and red hot.center connector for lighter socket is the hot side.
3000 watt eliminator with OLP and LUP CODES any Ideas
Assuming you have a 12VDC In 120V AC out 3000W inverter.
LUP indicates battery voltage is low, so firstly make sure:
1. You 12V battery is good, it's large enough a minimum of 75AH and probably much larger is recommended and it's fully charged.
2. Verify you are using the correct size copper wires from battery to the Inverter DC INPUT(s). If you keep wire short the wire size can be smaller, but if the DC input wires are longer then you will need to use thicker copper wires.
At MAx load you would be taking 250 AMP from battery, so for a 5% Volatge drop of .6 V for a 10 ft length of cables from battery to Inverter you would need to use a 1AWG copper cable.
http://www.calculator.net/voltage-drop-calculator.html?material=copper&wiresize=0.4066&voltage=12&phase=dc&noofconductor=1&distance=10&distanceunit=feet&eres=125&x=37&y=8
OLP is a overload condition, which means you may have to many high powered AC powered things connected to the Inverters AC outlets or maybe something that has large start up surge, ie devices large electric motors.
Or it could be all due to a faulty Inverter.
