20 Most Recent Panasonic WhisperCeiling Bathroom Fan FV-11VQ3 Questions & Answers
The roaring noise is probably the fan blades (looks like a hamster wheel) are worn out as it rotates on the spindle/shaft.
It may be a problem with the 4" exhaust ducting, that connects to the exit part of the fan, has come loose. Theres a damper (kinda like a flapper) at the fan/ducting joint may have broken off and may be sitting sideways in the ducting flapping around inside the duct.
At any rate I highly doubt its wiring. Sounds like its time to pull the fan cover off (turn the power off first via the wall switch or the service panel breaker would be even better) and look at the fan blades. Clean off any dust bunnies, lint, etc. and turn the fan back on. Did the noise stop?
If nothing looks out of place and it still makes noise you'll have to get in the attic and remove the ducting from the fan and see if theres a problem at the connection there. Maybe a squirrel put its bedding in the ducting? It happens.
Could be lots of reasons for the noise but wiring it wrong wouldn't cause roaring. The fan wouldn't work, or worst burn up, if wiring was the issue. The problem is the more than likely the fan blade assy is worn out or something is restricting the air flow in the ducting going to the outside of the house.
Panasonic... | Answered on Nov 23, 2012
Yes and maybe.
If you open unit, usually fan motor is plugged in, and motor is removable with bolts.
The problem is finding new fan that fits same housing without spot-welding and drilling.
I did google image search for "replacement vent fan motors" and results show choices.
For example Nutone:
http://nutoneproducts.typepad.com/nutone-products/nutone-bath-fans/page/2/
If you can locate same brand vent at local box store, you can use parts from new one to repair old one without project of replacing fan housing.
20 years ago, motors went to electric repair shop and they rewound the motor.
But today, motors are landfilled or shipped overseas for recycling.
All costs are energy, and right now, cost of re-wind is more than buying new motor, or new vent.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Panasonic... | Answered on Feb 21, 2011
The green wire is the ground, just like the bare wire. Attach black to black, white to white, and green to bare.
Panasonic... | Answered on Apr 08, 2017
Try Googling (noma)(052-8835-2)(manual) without parens for instructions.
Hardware &... | Answered 3 days ago
Panasonic WhisperCeiling Bathroom Fan FV-11VQ3 Logo
5 questions posted
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Hardware & Accessories
Most Popular Question
quiet bathroom fan makes roaring noise
  • Hardware & Accessories
