20 Most Recent Aube Technologies Aube 7-Day 40-500w Light Switch Timer Questions & Answers
Which timer do you have.
Copy following links to identify timer, then add a comment identifying specific timer, including how the timer was wired.
http://waterheatertimer.org/Aube-timers.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/How-to-wire-timers.html
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aube... | Answered on Sep 18, 2013
You posted under Aube timers.
Resourceful do-it-yourselfer would include brand and model number for ease of identification and best possible free answer.
Open following link to identify timer and access on-line manual
Most digital programmable timers say 'reset' if timer stops functioning as expected.
Aube reset button can be pushed using paper clip. Usually hold-in button for 3-4 seconds.
Other timer brands and models use different method for reset, including holding down on-off button while reset is pushed.
If timer will not re-program or function correctly after reset, then timer is probably defective.
Aube timers have internal rechargeable battery that is not replaceable.
Most in-wall and plug-in timers have 1 year limited warranty. If Aube timer was exposed to cold temperatures, then warranty is probably voided since cold temperatures adversely affect battery life.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aube... | Answered on Mar 18, 2011
You posted under Aube timer.
If you have different brand timer, add a comment with clear description of buttons so I can find the correct model number and post best answer.
Open following link to download manual for your Aube timer.
For example with Aube T1032: If you have different Aube timer, then open that manual for specific instructions.
Press PGM button to select Program1 ON.
So 1 and ON are displayed.
Press Day button to select choice of days for Program1 ON.
Press HOUR and MIN buttons to select ON time for Program1 ON
Next, press PGM button to select Program1 OFF.
Repeat steps for Day, Hour, MIN.
When program is finished, close and press the cover to return to normal operation.
Last, press and hold cover until AUTO is displayed, and now program will operate.
Aube... | Answered on Feb 25, 2011
Please review the technical manual for your Aube timer and check your wiring. I'm sure it is a oversight in the wiring.
I hope this helps you solve your problem...Please leave a comment...Thanks! Jim
http://www.aubetech.com/manuel/2/TI032.pdf
Aube... | Answered on Feb 13, 2011
Link below has information, images and manuals
Aube... | Answered on Jan 07, 2011
Fixya doesn't make timers.
Honeywell makes the Aube Timer
Aube timers are a new product with a rechargeable battery.
Batteries are susceptible to cold temperatures just as you suspect
http://www.aubetech.com/products/produitsDetails.php?noProduit=75&noLangue=2
Aube/Honeywell has a 'contact us' page
http://www.aubetech.com/contactUs/index.php
I sent an e-mail to Aube tech support about your question.
As soon as they answer, I will post their answer on this thread.
I also posted a page on Aube timers with links and manuals:
Aube... | Answered on Nov 13, 2010
Aube T1032 is 500W 7-day timer with full range programming
Aube T1034 is 500W 7-day Sunrise/sunset timer
Aube T1070 is 500W 7-day timer that turns lights ON at sunset and OFF at programmed time later in evening, say 11:00 pm
1) T1032 programming steps are lengthy> click link for manual
b1129f1.jpgAube T1032 buttons
Switch must be wire for display to show
Move slide switch to ON
Open door to see buttons
Set clock with present hour minute and day
Choose 12 hour or 24 hour format
Review operating mode : Auto for programs to run
Make a chart of your on-off schedule so there are no overlaps and conflicts when programming
Press PGN button
Display shows ON P #1 >>> this means you are setting ON time for program 1
Set hour minute day for ON time for program 1
Display shows OFF P #1 >>> this means you are setting OFF time for program 1
Each program 1-7 has ON time and OFF time plus day of operation
2) T1034 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI034.pdf
Timer must be wired for display to show
Open small door
Review buttons
Review operating mode: Auto if you want timer to turn on-and-off with sunrise sunset
Set the clock with present time / Choose 12 hour or 24 hour format
Use Hour button to set hour MIN button to set minute
Use CODE button to set daylight savings time
Set Sunrise-sunset parameters using tables that show in manual
Make a chart of programs
Set programs 1 thru 7
The above steps are 4 EZ steps for painting the Mona Lisa >>> please re-post question with detailed question
T1070 programming steps are lengthy> click link for manual
http://www.aubetech.com/manuel/2/TI070.pdf
You select mode
Pick your city's coordinates from chart so timer knows when sun goes down
Make a chart of the times you want timer to follow
Select program number
Set days you want that program to work
Set time for that program to turn off lights
Aube... | Answered on Oct 12, 2010
Smarthome has the T-1032 pdf manual
http://www.smarthome.com/manuals/4256.pdf
1) Test installation to see if your wiring technique is correct.
Open cover > set on-off switch to 'ON'
Press the tiny round reset button with paper clip
Screen displays 0:00, MO, MAN, OFF
Close cover
Push cover inward like a push-button (the cover is the manual override)
Lights should turn on
If lights don't turn on, then you need to rewire ... so re-post a re-wire question ... and then come back to this answer to program
2) Set Time and Day/ Correct time and day are needed for programs to work.
To start, notice on the screen - in the corners are little letters: MAN, MO, OFF. And to left of time is PM.
Set the Hour: Press hour button until correct hour shows, including PM or AM
Set minutes: Press MIN button until correct minutes show
Set the day. Press day key ... MO in corner changes ... for example TU is Tuesday, WE Wednesday, TU Thursday
Press one of the control buttons to finish operation
Programming overview
Timer allows 7 programs
Program 1, Program 2 etc
Each program has ON and OFF time
So you have to select Program 1
And then set DAY for Program 1, set ON time for Program 1, and then set OFF time for Program 1
Next you do the same for Program 2 , and then Program 3, 4 etc to 7
If you only want Program 1, then you do not need to set Programs 2 thru 7
Let's program
Press PGM button ... the timer screen show a P to right of time
The number 1 appears below P and indicates Program 1
Set days you want Program 1 to work: Press day button and you can see MO TU WE TH etc appear on screen.
If you want all week long, press day button until all 7 days appear in tiny print on bottom of screen
Now you have the Day set for Program 1
Notice the screen shows ON ... this means you are going to set the ON time for Program 1
First, Set hour you want Program 1 to turn ON: press Hour button until correct AM PM time shows on screen
Last, set minutes to go along with hour: press MIN button until correct ON time minutes show
You have the day, hour and minute set for ON time
Set OFF time for Program 1: we are going to set a Day, hour and minute you want Program 1 to turn OFF
Press PGM button, and notice that OFF appears in top right corner of screen
Set the day you want timer to turn OFF for Program 1 by pressing DAY button >>> Tip set same days you set for ON times. So if you selected all seven days for ON time, then select all seven days for OFF time
Set the hour and minute you want Program 1 to turn OFF by using Hour and MIN buttons as before.
OK, the ON and OFF day, hour and minute are set for Program 1.
To continue to Program 2, press PGM button until a 2 appears on screen below the P
If you do not want to set more Programs, then you're finished
To finish, press any control button
Close the lid, cross your fingers, you did good
Aube... | Answered on Sep 30, 2010
The neutral for that circuit must be connected under the neutral terminal connection set screw_on_ the GFCI breaker. The (usually coiled) white wire that is permanently connected to the GFCI breaker is then connected to the "neutral block in the panel."
Aube... | Answered on Feb 15, 2010
This is old timer since it still uses batteries.
Replace AAA batteries.
This timer also has preset programs. User cannot change preset programs which is the strangest thing I've ever heard about a timer, except vacation timers. It appears the timer turns on-off 6 times each day for no apparent reason that shows in manual.
Moreover, the timer has very complex instructions, whereas other timers are far easier to program.
Buy another timer.
Aube... | Answered on Jun 26, 2014
Aube Technologies Aube 7-Day 40-500w Light Switch Timer  Logo
17 questions posted
Top Aube Technologies Hardware & Accessories Experts
Overmod
Gene Haynes
Steve Pack
Steve Pack
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Aube Technologies Hardware & Accessories
Most Popular Question
aube digital timer 7 day model ti032
  • Hardware & Accessories
