20 Most Recent
Eagle Signal Br1 30min Reset Timer Questions & Answers
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
I need a manual for CRMC-A310JBEO For Sharp Air Conditioner Remote Control
The Sharp Air Conditioner Remote Control CRMC-A310JBEO comes with two timer-related functions: TIMER ON and TIMER OFF. To set the timer on the remote control, press the Timer button, then use the Temp + or Temp - buttons to set the desired time. Wait 3 seconds, then the timer function will be activated. You can turn off either function by setting its timer to "0.0h".
