20 Most Recent
Samsung 5528R Vacuum Questions & Answers
Samsung Quiet Storm 9048R hose break
OK ART THE FITTING THAT CONNECTS TO THE HOSE SHOULD HAVE TWO SMALL SQUARE HOLES OPPOSITE EACH OTHER YOU NEED TO PUSH TWO FLAT HEAD SCREW DRIVERS IN AT SAME TIME TO RELEASE THE SECTION THAT THE HOSE SCREWS INTO POP THIS APART THEN REMOVE THE SMALL PIECE OF BROKEN HOSE AND SCEW HOSE BACK ON REPLACE INTO FITTING SO THE SQUARES POP BACK INTO PLACE AND START VACUUMING HOPE THIS HELPS GLENN PS ANY VACUUM SPECIALIST WOULD BE ABLE TO HELP WITH THIS SMALL PROBLEM IF YOU WANT TO MEET ONLINE ABOUT THIS I WOULD BE MORE THAN HAPPY TO ASSIST
Samsung SC8571 VACUUM CLEANER
Either check your local region of EBAY for any vacuum cleaner repair specialists who may be able to sell you a replacement hose/parts OR enter your postcode in Australia for this Samsung customer service:
Dont forget to rate.
http://www.samsung.com/au/support/repairlocation/ServiceLocationsMain.do
Over heating while cleaning
There can be 3 reasons
1. The main dust collection receptacle is full. Empty it
2. The filter in between the receptacle to the machine is clogged. Take it out and wash it. Ensure it is dry before fitting it again as this is the inlet and must not be wet.
3. Look for a clip on attachment from where the air exits. Open this and clean the sponge and filter. I usually take it out and wash it squeeze out the extra water before using again. Since it is the outlet, it doesn't matter if it is damp when refitting.
I would advise that you take a picture before pulling it out so that you place the rubber gasket, sponge and filter in the same sequence as before after cleaning them. Happy Cleaning!!!!
