20 Most Recent ValuSoft Let's Ride: Corral Club for Windows Questions & Answers
Hey 1323164 you were right. I was having this same problem trying to run this game on Windows 10 but what ended up fixing it was opening up the folder on the disk, running the setup file in compatibility mode for Win XP (service pack 3), and running it in administrator mode. Then in the setup I ran custom install, and selected the Direct X install and selected "will not be available for program". Basically it would not be installed with the program. Then I pressed next and it installed and runs great! :D Thank you so much for that hint!
ValuSoft Let's... | Answered on Dec 27, 2017
windows 7 is no longer supported by Microsoft so there may be conflicts between the systems
put the disc for the game in a cd and go to computer and run the disc from the cd icon
ValuSoft Let's... | Answered on Oct 28, 2017
I have seen others with this same issue. Apparently you have to run the installation as an administrator. Simply right-click the setup icon and select run as administrator.
ValuSoft Let's... | Answered on Jan 03, 2014
You need to make sure it is MAC compatible, then if it is, check your OS (operating system) generally mac games require Snow Leopard or higher, but I would make sure. I have a mac too, and those are my 2 main problems. Good Luck and Have Fun!
ValuSoft Let's... | Answered on Jul 16, 2011
The game may have a crack file in its installation disc.....try copying it to the game's directory........or search for its crack online........
ValuSoft Let's... | Answered on Jun 24, 2011
If you are using Win 7, right click on the setup icon and run as administrator.
ValuSoft Let's... | Answered on Jan 08, 2010
To make the all the files of the game compatible to Windows Vista you need to install the game and then make changes to the game exe file.
Some game ".exe" file (executeable file) would let you make changes in the Compatibility option, whereas older games might not give that option at all.
You can still try to make the game compatible for installing it on the Windows Vista by following the steps below.
1. Insert the game disc in your CD-ROM drive, if the game setup or the autorun starts, exit it.
2. Open "Computer", Right Click the Cd Drive which has the game disk in it and select "Copy".
3. Go to your "Desktop" right click and then select "New" and click on "Folder" this should create a new folder on your desktop.
4. Open the New Folder and then Right Click and select "Paste".
6. After all the files are copied to the "New Folder" without any error messages then locate the file "Setup.exe" or "Setup" and right click and click on "Properties".
7. In the new window click on the "Compatibility" tab and run the program in compatibility mode for "Windows XP Service Pack 2" and then click on "Apply".
8. After applying changes double click on "Setup.exe" or "Setup" to launch the installation.
9. After the game is installed go to the game directory and find the "LetsRide.exe" and click on "Properties" and repeat step no.7
You can delete all the files copied from the CD after completing the installation
The game files need to be copied to the hard drive because the files on the game disk would not let you make changes while on the disk.
There are lot of files that need to be changed in order to get full functionality and to communicate with operating system and the hardware, hence there is no guarantee that the game might run even in cases where you will successfully install an older version of the game with the above mentioned steps.
The same set of steps can be used for installation of older games installation on Windows Vista.
ValuSoft Let's... | Answered on Mar 15, 2009
You might try emailing them to see if they have an online version. Contact Technical Support
ValuSoft Video... | Answered on Feb 18, 2015
ValuSoft Let's Ride: Corral Club for Windows Logo
Popular Tags
18 questions posted
Top ValuSoft Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Tom Chichester
ray gallant
ray gallant
Are you a ValuSoft Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • ValuSoft Video Game Consoles & Games
Most Popular Question
ve lets ride
  • Video Game Consoles & Games
