20 Most Recent
Gestetner DSm516pf Digital Copier Questions & Answers
I can't print because i
I will be very glad if somebody finds a solution to this problem.
Lucasandino, did you solve this problem?
Luciano
3/22/2011 2:39:31 AM •
Gestetner...
Answered
on Mar 22, 2011
I can't print on the
MacOs just print
with PS (PostScript).
Probably your machine do not have it (moustly because it is extra and it is to expensive)
But you can download from a web sit called "Gutenprint for Mac OS X" (make a
search on
Goggle and you will find it) a generic driver for PCL printers
You will not be able to take full advantage of the machine but... work.
You can also take a look on this web site:
http://www.linuxfoundation.org/collaborate/workgroups/openprinting/macosx/hpijs
I didnt try it but Looks like there is a printer driver that will work with any PCL printer. Just have to install the HP ijs driver.
3/22/2011 1:21:55 AM •
Gestetner...
Answered
on Mar 22, 2011
I cannot print on my
MacOS does not support PCL driver (only the latest versions of MacOs support it). You need to install the PS (PostScript) Driver but for that your machine needs to have PS installed to.
This is optional on several models.
If you really what to print with your Mac and extract all functionalists you have to put this optional.
You could go around the problem by installing in Your Mac a virtual machine with Windows...
Hope this helps
3/18/2011 10:39:16 PM •
Gestetner...
Answered
on Mar 18, 2011
On my Gestetner DSc516pf copier the message keeps
Do you see Any Error Message on the Display?
Unplug the Unit for Few Minutes, say 30 minutes and then Turn it ON. If the Problem Persists, more often it is a Hardware Failure.
In these Models, there is an Electronic Sensor that senses the Paper Jam. It seems that it might be at Fault. The Sensor is not Serviceable and it has to be replaced. These Sensors are not easily Available in the Market.If you could find the Sensor, i would be able to Guide you to Fix this. You need to have Schematics which we might find later on, once you would get the Sensor.
Note - I am taking into consideration that you have already checked and made sure that there is no Paper Jam.Sometimes, you might find small clips of Paper in and around the Rollers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
4/1/2010 11:22:46 PM •
Gestetner...
Answered
on Apr 01, 2010
How would I identify faulty fault sensors in gestetner MP2501L copier and replace them?
You can't. As I said you need the service engineer with the laptop. These Office Machines are NOT consumer serviceable. They hook up the laptop with the Ricoh software and it interrogates the computer, the mainboard and everything on it. The error message you get is from the brains inside it..Original question and answerhttps://www.fixya.com/support/t29802178-am_posting_again_stripped_off_gestetner..
Am posting again. I stripped off gestetner MP2501L 8 times due to problem ' see instructions on right side to solve' but same. No paper inside. What is the actual problem.
Hello Christopher
Are you in the Philippines? I notice that your copier has changed from Ricoh to Gestetner? We are a North American website.
This is a commercial office machine, and from my experience of them is that on the right side you will see on the inside, a list of instructions for where to check for obstructions. It seems you have already done this 8 times! Frustrating! Try this;
Open the right side cover, unlatch all the bits at that side.
Open the straight pass door on the left side.
remove ALL the paper drawers.
Get a powerful flashlight, look in all the spaces you have just created, especially at the edges of drawers and paper pathways. You are looking for a tiny piece of paper that one of your employees carelessly left behind after a paper jam.The one I found was right at the back of the straight pass door. When a sensor is covered, it creates that message.
If that fails, Ricoh will have to come and attach their Laptop scan software to it which will tell which sensor is obstructed or has failed.
Sc 569 for ricoh mp 5500
sc 569 is the pressure roller contact sensor error Troubleshooting Procedures: 1. Check or replace the harness of the pressure roller contact sensor. 2. Replace the pressure roller contact sensor. 3. Replace the pressure roller contact motor
SC 569 Error code in MP 5500
